Old 04-29-2026, 12:34 PM   #1
Sparky
Sparky's Avatar
Default Found a number stamped on top of my block
I took my cylinder head off and found this number stamped on the block next to a cylinder. What do you suppose it is? Machine shop mark? I know the engine has been worked on sometime in the past because it has .080 oversize pistons.
Sparky is offline   Reply With Quote
Old 04-29-2026, 01:46 PM   #2
gdmn852
gdmn852's Avatar
Default Re: Found a number stamped on top of my block
Hello, not sure what “54” would mean. But authorized Ford engine rebuilders would affix a tag usually near the oil filler on block that had crank undersized and bore oversize. Did have an engine that had oversized bore and was stamped on top surface of block .
gdmn852 is offline   Reply With Quote
Old 04-29-2026, 01:51 PM   #3
Sparky
Sparky's Avatar
No, there is no tag, but one of the pistons is stamped .080 on top. Strangely, none of the other pistons have a stamp.
Old 04-29-2026, 02:07 PM   #4
Benson
Could be the amount of cast iron removed when they re-surfaced the top of block!
Measure from oil pan rail to top of block:
11.500 minus .054 = 11.446 INCHES
OF COURSE THAT ASSUMES that block was only re-surfaced ONE TIME!
Old 04-29-2026, 05:12 PM   #5
ModelA29
ModelA29's Avatar
Probably the shop stamped it to keep track of the work done on it. I'd wager the last 2 digits of the invoice was 54. Only one piston stamped means only one hole got bored. These were budget cars rebuild and keep running at the lowest cost.
ModelA29 is offline   Reply With Quote
Old 04-29-2026, 06:36 PM   #6
mcgarrett
Also possible that after machine work had been done an inspector stamped his number there.
Old 04-30-2026, 05:17 AM   #7
nkaminar
nkaminar's Avatar
1954?
Old 04-30-2026, 09:32 AM   #8
Fullraceflathead
Fullraceflathead's Avatar
I'm guessing 1954 is the reason for the stamp they either did a head gasket or some other work to the engine.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 04-30-2026, 11:36 AM   #9
gdmn852
gdmn852's Avatar
Hello again, not too unusual in that era just to do what was necessary to get it back on the road, I have a Model a engine that two of the connecting rod journals are.010 and other two are .020 . Recall reading about a car from the 1920 s had a broken connecting rod and they drilled it and with a piece of strap steel, bolted it together!
Old 04-30-2026, 04:32 PM   #10
Sparky
Sparky's Avatar
You made me curious so I measured the bores with calipers, and they are all .080 over. Apparently the machine shop just stamped one of the pistons and didn’t bother with the other three.
