Old 04-18-2026, 07:23 AM   #1
allenmichael
Default grounding bob drake fuel sending unit
1936, still 6 volt, new fuel tank and sending unit. Continuity exists between tank and gauge. will grounding sending unit to metal floor of car be enough ( which I did) however unit still not reading. Should i move it to a heavier gauge ground source?
allenmichael is offline   Reply With Quote
Old 04-18-2026, 08:03 AM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: grounding bob drake fuel sending unit
Grounding to a clean spot on the floor is more than adequate.
You most likely realize that the Drake units are "iffy" at best.
Old 04-18-2026, 09:59 AM   #3
JayChicago
JayChicago's Avatar
Agree.
Could be bad sending unit, or a bad gauge.
To test the gauge: with a helper watching the gauge, switch on, briefly touch the end of sender wire directly to ground. With zero resistance there, needle should move towards full.
If it does, assume gauge is good, must be bad sender.
Old 04-18-2026, 10:23 AM   #4
allenmichael
Jay, on which end of the circut of the sender wire do you directly touch to ground? Is it leave sender wire connect to sender and then touch gauge end to a ground? or jump from ground at sender unit to sending terminal? hope this makes sense.
Mike
Old 04-18-2026, 04:55 PM   #5
JayChicago
JayChicago's Avatar
Disconnect wire from sender terminal, touch that wire to ground.
Or yes, as you said, leave connected to sender terminal, rig a jumper wire from sender terminal to ground. Will give same result.
Old 04-18-2026, 09:58 PM   #6
Karl Wescott
Karl Wescott's Avatar
Original gauge... Likely a King-Seely system. I do not really understand it but what I do suggests the sender sends pulses to the gauge and bumps the indicator, the more pulses the higher the indicator goes (don't ask me how).
Aftermarket sender... (used by most aftermarket gauges) senders use a rheostat (variable resistor) to vary voltage and the gauges is basically a voltmeter.
King-Seely gauges will ocassionally, but not always kinda work with the aftermarket sender. Empty could show as empty, Full could show as full, but anything between will be random to that gauge and sender.
There are some great threads on the subject with 747 explanations of how the King-Seely system works. Search for them. (747 jet... way over my head).
Karl Wescott is offline   Reply With Quote
Old 04-18-2026, 11:30 PM   #7
JayChicago
JayChicago's Avatar
Yes, he has a modern sender which will never produce accurate readings on an original K-S gauge. But it should show something.
My understanding is he is getting no needle movement at the gauge. Probably a bad sender. Probably the tiny rheostat coil in the sender is broken open.
Old 04-19-2026, 08:34 AM   #8
allenmichael
Thank you Jay, that is exactly what I needed to know. Now off to see what is what!
Mike
Old 04-19-2026, 08:53 AM   #9
kurt v
I don't know if i read correctly or not but by using a sender up into the 50's (still 6 volt) will work with the orig gauge, but i may be wrong.
kurt v is offline   Reply With Quote
Old 04-19-2026, 09:33 AM   #10
glennpm
glennpm's Avatar
Jseery gave us an explanation.
https://www.fordbarn.com/forum/showthread.php?t=165773
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 04-19-2026, 09:54 AM   #11
1942deluxe
1942deluxe's Avatar
On my 46 the dash gauge wasn't registering after installing a new sender. Checked the connection at the tank and it was loose. Added a small washer and it worked.
Old 04-21-2026, 02:40 PM   #12
Automotive Stud
Automotive Stud's Avatar
I had the float sink on a new Drake sender. Put my original float on it, which was bigger and I had to bend the arm, and it works again. Just because it's new doesn't mean it's good.
Automotive Stud is offline   Reply With Quote
Old 04-21-2026, 06:47 PM   #13
rotorwrench
rotorwrench's Avatar
The big unknown is what Ohm range would give a King Seeley quantity indicator a full sweep from E to F. The current pulse system didn't have the same range due to the way it controlled power at the indicator. The indicator function is the same theory but current control doesn't involve any rheostat. The float arm movement affected the movement of the sender breaker points on the bi-metallic regulator switch arm. K-S used a resistance wire spool and a carbon resistor to calibrate the system circuit. If you chuck the original sender and convert it to rheostat, the Ohm difference between E and F on the indicator need to match up with the resistance range that gets it there.
Ohm controlled quantity systems use specific Ohm values and from research, most are limited to three or four different values between different manufacturers. They should test a K-S indicator with a good variable resistor test aperatus to find what range effects it and manufacturer one that works. I think they just got one of the off the shelf units that's close and called it good. I'd be surprised if they care whether it works or not.
Old 04-21-2026, 07:14 PM   #14
34fordy
34fordy's Avatar
I have found, after too many length adjustments for my Drake sender, it reads full for a long period of driving and then down to 1/4 full quite quickly. That is when I head to the gas station. Today the gauge indicated about 7/8 full. I add 9.3 gallons. The worst thing is a Ford sender will not fit in the hole in the Drake tank. Had to buy a Drake sender. Purposely ??
34fordy is online now   Reply With Quote
Old 04-22-2026, 03:40 PM   #15
rotorwrench
Yep, the bungs are different. Some can use an adapter but I don't know which ones.
Old 04-23-2026, 12:12 PM   #16
JayChicago
JayChicago's Avatar
Wouldn't that be nice. Probably never see it happen.
Old 04-23-2026, 12:24 PM   #17
34fordy
34fordy's Avatar
No matter how important these issues are to all of us we have moved into the
"WORLD of IRRELEVANCE" !
