I have one of these regulators in my '35 pickup that is set up for 12v. The 6V gauge reads about 1/2 full when the tank is empty. The sending unit is from Drake that I bought along with a new fuel tank.
Can I just add some resistance to this circuit to make the gauge more accurate? Thanks, Heard
Do I look like I have a plan B? |
Yes. My modern aftermarket sender had the gauge needle at 1/4 when tank was empty. Was able to get it down to the E line by adding a resistor just ahead of the sender. Is still totally inaccurate at the upper end of the gauge.
Through trial and error, settled on 11 ohm resistor in my case. Each situation will be different. But the float arm needs to be adjusted first. Arm should be able to move all the way to the bottom of its travel on the sender, just before the float bottoms out on the floor of the tank. |
Changing voltage of the system changes the current draw so a person needs a King Seeley 12-volt use sending unit from 1956 or later or change the indicator to a 12-volt unit depending on which way it's being modified. Those current chopper type voltage regulators work for some applications but not all. Some of them aren't the pulse type but use a modern solid state three pin voltage regulator. The Runtz units are solid state but a person needs one for each changed indicator system ie water temp, oil pressure, and fuel quantity if the vehicle has all three in King Seeley types. They just drop the voltage to 6-volts or so. Last edited by rotorwrench; 04-17-2026 at 01:12 PM. |
