Hi Fordfriends.
Does anyone know if it`s possible to replace the oiltube that provides oilpressure to the camshaft bearings on flathead 8BA engines? I have a good block with a bad oilpipe and a cracked block with a good pipe. Thanks. Rolf in Sweden. |
I've never done it but I believe people here have said they have done it. I think people say it is better to pull the tube out. It looks like it is threaded but they are not threads, just a series of circular marks, probably to provide a high spot at each part where it fits the block. You could pull the good pipe from the bad block as a test. It might be possible to thread a tap into the pipe and use a bolt as a puller. Or maybe drill a hole in the pipe in a place that is easy to access, insert a bolt from the end and weld it in through the hole. Once fitted in then new block the weld could be drilled out and the hole welded up.
Like I said, I've never done it but wanted to share some thoughts. Hopefully someone with direct experience will speak up. Mart. |
I would start cutting the casting away to get the good tube out being carful not to damage the tube. Once it is out you'll have a good idea how its put in and how to ge the defective one out of your good block without damaging the block.
#4 | |
I recently had an 8ba block thoroughly cleaned by my machine shop and yes, the tube was threaded and I presume a bolt was used as a puller. I was told it wasn't a big deal.
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
Create a modified slide hammer type of puller. You’ll probably want to tap the threads a little deeper for the puller tool. You shouldn’t have to go crazy wacking away with the hammer….just be patient with normal pulls on the slide. It should walk right out. This information came from a machine shop owner who has done them before. Sometimes the block has been sitting with water in there but most likely the world of mice has lived in there. Mouse pee is nasty stuff……the oil galley pipe doesn’t survive it well.
VANPELT SALES LLC Cincinnati, Ohio Office: 513-724-9486 www.vanpeltsales.com www.classictransmission.com |
As written above its not that hard to remove the tube. When I did this a job myself a few years ago on two 8BA blocks I simply taped deeper into the tube so there was a good amount of threads to pull against. Then I used a slide hammer to remove the tube. Just to be sure the tube would come free heating the center casting was also done overall it was easy to do.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
Thank you all for all good advice.
Rolf in Sweden |
