Old 03-22-2026, 03:50 PM   #1
48JOHNPH
Default Rear wheel adapter plates
I'm trying to install an 8.8 rear differential from a 95 Ford Ranger in my 37 Slantback and the bolt pattern is different from my stock 37 Wheels. Do they make an adapter plate that will bolt to the Ranger axels and adapt to my stock 37 wheels?
48JOHNPH is offline   Reply With Quote
Old 03-22-2026, 03:59 PM   #2
TJ
TJ's Avatar
Default Re: Rear wheel adapter plates
You might check with Speedway Motors. They used to have adapters for the small bolt patterns to the large patterns.
Old 03-22-2026, 07:04 PM   #3
51504bat
51504bat's Avatar
5 on 4 1/2 to wide five adapters have been covered here and the HAMB several times. Do a search and you'll see all about what's available and the issues involved.
51504bat is online now   Reply With Quote
Old 03-22-2026, 07:24 PM   #4
Newc
Newc's Avatar
Note; Circle track racers adapters use 5/8" lugs- still work tho. Newc
Old 03-23-2026, 08:13 AM   #5
51504bat
51504bat's Avatar
In one of the threads I referred to in my earlier post there is a Dorman part number for 1/2" studs that can be used to replace the 5/8" studs on the Speedway adapters.
Old 03-23-2026, 09:51 AM   #6
34fordy
34fordy's Avatar
I use circle track adapters for holding wide five wheels when mounting tires. The 5/8 lug bolts fit in the wide five wheels just fine. The 5/8 lug nuts have a different taper so I turn the taper on my lathe to match. However I doubt that it is necessary to do that.
34fordy is offline   Reply With Quote
Old 03-23-2026, 02:00 PM   #7
48JOHNPH
Thank You everyone for your input
