Old 03-14-2026, 02:49 PM   #1
Ray in La Mesa
Default 3.14 Day
My step daughter is a math teacher & told me today is pi day, enjoy it with whatever pie you like.
Ray in La Mesa is offline   Reply With Quote
Old 03-14-2026, 03:17 PM   #2
California Travieso
Send a message via Yahoo to California Travieso
Default Re: 3.14 Day
I would like to enjoy it, but sadly they closed our Polly’s Pie Shop here in Moreno Vally last week. They could have waited until after Pi day.
David Serrano
California Travieso is offline   Reply With Quote
Old 03-14-2026, 03:29 PM   #3
Joe K
Joe K's Avatar
Area of a circle PiR2 (pie R squared)
No - pie are round - cornbread are square.
Joe K
Shudda kept the horse.
Old 03-14-2026, 04:06 PM   #4
Elmo Rodge
Elmo Rodge's Avatar
pi are 3,14159265358979323846. How do I know this? It's my birthday. 78 is just a fond memory.
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 03-15-2026, 11:01 AM   #5
Chris in WNC
Chris in WNC's Avatar
Joe K
Joe, I make my cornbread in an iron skillet so my cornbread are round.....
no more model As for now........
Chris in WNC is offline   Reply With Quote
Old 03-15-2026, 12:25 PM   #6
atch
atch's Avatar
Many years ago there was a restaurant here in Columbia, Missouri owned by "Poor Ken" and "Lonesome Del". They made their own tv commercials using a blackboard and chalk with "pi r squared" (the actual mathematical symbols) written on the board. One would say "pi r squared". The other would say "no, pie are round". Then "pi r square". Then "no, pie r round". This went on three or four times then one miraculously had a pie in his hand and said "pie r messy" as he hit the other one in the face with the pie. They made many of these commercials but the wording and the pie-in-the-face were always there.
atch (Mike Atchley)
Columbia, Missouri
atch is offline   Reply With Quote
Old 03-15-2026, 05:44 PM   #7
Joe K
Joe K's Avatar
We took on the Cornbread are square phrase in College Pre-Calc math, but I think it originally was part of a "Hee-Haw" routine.
Looking up the phrase on the Internet it seems a southern/appalachian colloquialism.
Joe K
Old 03-15-2026, 06:25 PM   #8
nkaminar
nkaminar's Avatar
314 trillion digits of pi was just calculated on a single Dell PowerEdge R7725 server that ran constantly for nearly four months. See https://www.livescience.com/physics-...ely-irrational
For most engineering calculations only 4 decimal places are needed.
Old 03-15-2026, 06:43 PM   #9
Joe K
Joe K's Avatar
One of the entry level engineering course examples involved the "engineering effect" that "significant digits" has on the final outcome.
To demonstrate this, the Professor calculated some common engineering calculation (I think it volumetric compression in a cylinder) and instead of Pi used to calculate the area, he used "3." Surprisingly, it didn't make that much difference in the answer, actually less than the 3.14/3 fraction/percentage (4.06 percent) that starting with the incorrect value represented.
It became our task for that evening to identify why this was so. Which meant doing the calculation "in parallel" for each step and comparing the intermediate answers all the way down to the end.
Joe K
Old 03-15-2026, 06:48 PM   #10
JayJay
I cheat - all of my calculators have a "pi" key, which I presume is accurate to several decimal places more than 4. Although I agree, a fifth decimal place would only affect the final result to a factor of 0.0032%.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 03-15-2026, 07:45 PM   #11
atch
atch's Avatar
113/355 is close enough for 99.99% of calculations. Divide it out on your calculator and compare.
EDIT: I have the numbers reversed. it's 355/113.
atch (Mike Atchley)
Columbia, Missouri
Old 03-15-2026, 07:48 PM   #12
atch
atch's Avatar
And 113355 isn't very hard to remember. If it was I couldn't remember it. First 3 odd numbers.
atch (Mike Atchley)
Columbia, Missouri
Old 03-15-2026, 08:05 PM   #13
CT Jack
CT Jack's Avatar
Archimedes also proved that the ratio of the area of a circle to the square of its radius is equal to PI (A/r square = PI)
CT Jack is offline   Reply With Quote
Old 03-15-2026, 08:06 PM   #14
Trapdoor2
Trapdoor2's Avatar
I always used 22/7...
3.17 is more important...'cause that's my birthday.
I've eaten a lot of green birthday cake.
'31 Ford Deluxe Coupe "The Green Hornet"
Trapdoor2 is offline   Reply With Quote
Old 03-15-2026, 08:59 PM   #15
Mike1291
Mike1291's Avatar
In the 2010s when I was in college, all of the math professors told us to use 3.14 for pi and that any additional significant digits were unnecessary. On one occasion I used nine significant digits on a quiz and the professor got mad at me and told me to never do it again! It was either from that or from the times I'd hand write how I think I needed to finish the problem but didn't know how to
Feb '31 Standard Coupe
Member of the Little Rhody Model A Club & MARC
Mike1291 is offline   Reply With Quote
Old 03-15-2026, 10:28 PM   #16
updraught
updraught's Avatar
It was 14.3 here and Right Hand Drive on the left of the road, the water spun clockwise down the drain and the cheese was yellow.
updraught is offline   Reply With Quote
Old 03-16-2026, 02:46 AM   #17
California Travieso
When I was in college in the late 1950’s, we used slide rules that were accurate to two significant figures, so 3.14 for Pi was adequate.
David Serrano
Old 03-16-2026, 08:56 AM   #18
JayJay
I think you mean 355/113, don’t you? Or 1/(113/355)?
JayJay
Old 03-16-2026, 08:58 AM   #19
nkaminar
nkaminar's Avatar
No calculation of Pi is correct, even the ones with trillions of decimal places are approximations. Pi is an irrational number.
The more accurate approximations are only important in things like calculating the curvature of space-time.
The first calculations of Pi were done by calculating the total length of the sides of a polygon and continuing to increase the number of sides until it was almost round.
Several algorithms have been developed for calculating Pi, see https://en.wikipedia.org/wiki/Approximations_of_pi
You calculator stores a value of Pi instead of calculating it each time. That saves time when doing work on the calculator.
355/113 is accurate to the 7th decimal.
Old 03-16-2026, 09:04 AM   #20
JayJay
David Serrano
I went through school in the early ‘70s, just at the transition between slide rules and calculators. My dad’s high school graduation present to me was lunch then a trip to the K&E dealer in San Francisco to pick out a new bamboo log-log slide rule for college. He went to engineering school in the late ‘30s. Even into the 80s he would run a set of numbers on a calculator, then whip out his slide rule to check himself. I still have his slide rule (although mine, regrettably, has been lost to posterity).
We weren’t allowed to use calculators on exams when I was in school. Something about they were considered “elitist”. Gotta love that California thinking, even 50+ years ago.
My “go to” calculator is the HP 15C, both “hard copy” and app emulator.
JayJay
