My friend Scott lost everything he owned in the Altadena fires last year. I am trying to return his KRW tools to working condition. Those tools which have acme threaded parts are literally welded and refuse to budge. Does anyone have any ideas on how to get these parts moving again ?
40larry |
Larry get some “Howes Penatrant”. Not aerosol it’s challenging to find and used to be a Mac Tools exclusive item but I believe now available through Amazon. Amazing stuff. Have freed many galled up bolts in both steel and aluminum. Good luck.
Available on Amazon and here is the manufactures web page:
https://howesproducts.com/products/m...d968093f457bf0 |
If all else fails, fire locked them up I bet fire would loosen them up as well. I'd pull out the torch and try and turn while hot.
Gosh, hope you are able to save some of those tools and that your friend Scott was able to get a building permit.
I got the Bolt Buster brand and have yet had it fail getting things unstuck. Unbelievably useful tool. |
First thing I would do is soak them in a barrel of molasses. Its really cheap, lasts all summer (does not wear out, like evaporust, which is really good but very expensive), you buy a bag at the farm store, its horse feed.
Dump a 25lb bag in a 55 gallon drum, or kids pool full of water and soak them for weeks. This will be only the first step, get the surface rust off and certainly other more drastic methods will be required to get things loose. Again, its cheap and lasts all summer. Folks in a mild climate should always have a batch to dunk old parts into out behind the shop. |
I've gotten seized, rusted bolt threads moving again with a propane torch and wax from a candle...
#9 | |
There is an additional issue involved in the restoration: The fire will have annealed the tools, rendering them unsatisfactory for heavy duty. Perhaps someone here can advise on a heat treatment to restore the correct hardness.
Alan |
Very true! I had some transmissions that had gone through a fire, and the gears were all so soft a file would cut them.
#13 |
You are right. Getting a building permit has been going on for months !
#14 |
Larry, it would be a big help to us if when you respond back, identify who you are responding to.
Alan |
#15 |
#16 |
Tony How do I post that I am responding to a thread number ?
#17 |
Option 1. On the lower right hand of the message box there is a button "Quote". Click on that. Option 2. On the upper right hand of the message box there is a counter that numbers the posts (for example) "#16". You could edit the message title (as I have done) or use the post number in the body of your reply. |
#18 |
#19 |
