Old 03-01-2026, 08:55 AM   #1
3W Hank
Default FH std heads
I has a 59 block that has a crack down in oilrail but issue it's overbored max.
Idea is has a nice show room engine that might get a future.
I has become to really like the early style but post war with the Weiand hi-rise that might be a pre war intake but fit that style with std heads on.
Ex how Hendersons roadster engine look like, se picture.
I has a Kurten modify LZ V12 distributor, and I also has 2 Stromberg 97.
I also has crank and rods and a oilpan.
The engine going to my 32 5W coupe is more a full race engine with a Merc -41 block with aluminium L&S heads, and that has a set up combo that I will use.
I found a set of Ford heads ( told to be PU ) but there was also Mercury heads and Ford heads ( not PU )
-Some information on this (?)
This intake Henderson used, is that a Weiand or a Edelbrock ?
I actually like this early modest style. Less, but more.
3W Hank is offline   Reply With Quote
Old 03-01-2026, 01:47 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: FH std heads
Hanks the intake on the engine is a Weiand this is what it looks like up close.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 03-01-2026, 02:45 PM   #3
petehoovie
petehoovie's Avatar
Ronnieroadster
Old 03-01-2026, 03:47 PM   #4
3W Hank
Ok, good to know.
The heads was in aluminium, just a note ( the Canadians ? )
Old 03-01-2026, 05:50 PM   #5
Ronnieroadster
Originally Posted by 3W Hank View Post
Ok, good to know.
Its difficult to tell from the engine picture if the heads are aluminum. If they are i would expect a more lighter color overall in the picture being aluminum. It looks like the heads may be the same color as the block maybe a shade of blue or purple ?
Ronnieroadster
Old 03-01-2026, 06:13 PM   #6
petehoovie
petehoovie's Avatar
Ronnieroadster
Old 03-02-2026, 12:09 AM   #7
3W Hank
This heads are NOS aluminium told to be PU.
Old 03-02-2026, 02:40 PM   #8
alchemy
alchemy's Avatar
Did someone say Weiand and stock heads?
alchemy is offline   Reply With Quote
Old 03-02-2026, 03:15 PM   #9
petehoovie
petehoovie's Avatar
Old 03-04-2026, 06:54 PM   #10
3W Hank
Love it, real art !
