I has a 59 block that has a crack down in oilrail but issue it's overbored max.
Idea is has a nice show room engine that might get a future. I has become to really like the early style but post war with the Weiand hi-rise that might be a pre war intake but fit that style with std heads on. Ex how Hendersons roadster engine look like, se picture. I has a Kurten modify LZ V12 distributor, and I also has 2 Stromberg 97. I also has crank and rods and a oilpan. The engine going to my 32 5W coupe is more a full race engine with a Merc -41 block with aluminium L&S heads, and that has a set up combo that I will use. I found a set of Ford heads ( told to be PU ) but there was also Mercury heads and Ford heads ( not PU ) -Some information on this (?) This intake Henderson used, is that a Weiand or a Edelbrock ? I actually like this early modest style. Less, but more. Last edited by 3W Hank; 03-01-2026 at 01:07 PM. |
Hanks the intake on the engine is a Weiand this is what it looks like up close.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
#3 | |
Ok, good to know.
The heads was in aluminium, just a note ( the Canadians ? ) |
#5 | |
Ronnieroadster
#6 | |
This heads are NOS aluminium told to be PU.
Did someone say Weiand and stock heads?
Love it, real art !
