I was going through some old boxes of parts that I hadn't had open for years and found these grease fittings and grease guns. I'm pretty sure these are original Model T fittings but I wanted to check with the experts on it. What say ye.... Thanks, Leon |
Not for a Model T. Model Ts used oil in most places but just a few where a grease cup was used.
Alemite came out with those somewhere in the 1920s. The bayonet type connection would hold the grease gun against the fitting better than just pushing against pressure. The design was offered for Fords. This link has information and an an Alemite specific link as well. They weren't used on Ford OEM products but could be installed by the owner or his service provider.
https://www.mtfca.com/phpBB3/viewtopic.php?t=36795 They had dust caps that were twist locked over the fitting to protect from contamination. Not a bad idea but they were kind of big. |
use them if you have them. Personally I drive my car and it isn't a points car so I use modern Zerks in the 6 places grease cups would have been.
Thanks everyone. They have been buried in my storage shed for at least 27 years and just saw the light of day this last week.... ![]() I just bought a driver '30 Model A pickup so maybe I could use them on it instead of the push on ones that are on there. I will try it. |
Chevrolet, Buick, Dodge Brother used them too.
Have fun. Packing the grease gun with grease is only half the fun!
That grease gun looks like the one I have been using on my Model As for decades'
#13 |
Unless you have the type of fitting shown in the first picture, it will not work.
#14 |
The front bearing on a model A water pump can take a general purpose grease and has one of the conventional fittings but the rear bushing takes a low melt grease and has a special fitting too keep from coolant intrusion and possible leakage (screw on cap).
There are multiple types of model A pumps with the OEM type and several leakless types so it also depends on the type of bearings for those. |
