Questions on Wittek clamps.
First. Are they numbered in sizes ? For example I has 5/16” rubber in US made fuel lines betwwen the LZ carbs but plan to has 3/8” from tank under car to firewall. I also has water tubes ( FH ) and I think OD on rubber might be round 2.3”. Any suggested sizes ? Then, how are the periods, can one see dates, if had the older holes or cadmid surface or steel. I has bought some from 2 ( 3 ) places but will get them soon but now I bought 3/8” as he said work fine and dated 4/48. No holes but look like a steel shell. Others I bought, seen pictures is cadmid surface some with holes, some not. No detail on numbers ( size ) or date. Will soon know. I has only 2 of the larger ones ( 60 mm ) But I need 10 more. Its not that easy try figure all this out and find the parts. Some of my buddys say I’m a nut. Shore, I can go to Walmart, but its not that fun. |
For fuel line, you need Wittek's #2. They are getting VERY hard to find. Nystrom is making new ones if you can't find old ones.
The ones I have seem to all be stainless steel, but with different coatings depending on when they were made. I am a stickler for details and hose clamps are one of those things where I have no issue paying up to ensure they fit the era of my car. I've buy #2's whenever I can find them. |
The ones I bought was just told be either fit 5/16 or 3/8, but if you say Nr 2 how wide is thoose in diameter ( lose ) ?
Do you has 5/16” rubber fuel lines to carbs ? |
Nystrom repros? Any link?
https://nystromperformance.com/produ...uel-hose-clamp |
#7 | |
Here is the hose I've used. |
I has around 30 of the now and this was I bought today dated 4/48, just as I like ! ( Nr 2 )
Super happy. |
^^^ Fuel hose from Turkey. I've only just started noticing Turkey in some parts here and there.
Wittek clamps are used a lot in early Corvettes. They have been re-popping them for at least 40 years. Any dates during that period are readily available. I would expect that's not an unusual case.
Corvettes don't use the thumb screw style clamps that the hot rodders want.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
The thumbscrews are the easy part.
#13 |
Not sure on which size clamps are used on Vettes, but #2's are very hard to find.
#14 |
#15 |
Here is my 3 orders, hard to think this is repro and I guess it’s 40’ most of them.
Some told me early ( 40’s ) is cadmidded but 50’s has steel band but the ones dated 4/48 has steel bands. Last edited by 3W Hank; 02-13-2026 at 03:37 PM. |
#16 | |
Mine are mix of stainless and cad plated. Could be for different applications. I'd assume stainless was aviation, but I have no way to verify. |
#17 |
Tim, when I has all of them here I will show all details of them.
This is fun. |
#18 |
I bought some of the nystrom clamps when they first came out (just a few months ago if I recall correctly). I haven’t installed them yet. Let me know if anyone wants detailed pictures of them. They are not installed yet as my car is at the interior shop.
40 ford coupe Build -https://www.jalopyjournal.com/forum/...coupe.1277406/ |
#19 |
It always good when good repros comes out, please show them.
I think the old Nr 2 is not that hard to find, but the bigger ones to water tubes is really hard. I has only 2 of them, but I has 12 NOS std Ford. |
#20 |
On Wittek clamps to FH water tubes, I has the std Ford clamps and they are
marked A - 2.1/8 ( 2.125" ) Open ( end of screw ) they are around 2.20". One friend showed me his Wittek clamps, marked #36 and showed the rubber hose is 54 mm or as the std Ford 2.1/8". The ones I bought, I has not them here yet is 60 mm or 2.36". -But seller told me that is what he used. The bigger ones is hard to get, so now I has just 2 of them. Ideas of this ? |
