Any of you "transmission" guru's can suggest a "lock ring" pliers set brand??? I bought a set of them BUT the serrations don't grab the one side of the angled lock rings holding the front and rear bearings and slide off just before getting the ring out of the grove. Any suggestion greatly appreciated.
Robert,
This can be one of the most frustrating jobs. I use a set of Craftsman pliers (part # 47386) but I believe they are made for them by Lang Tools for this job. That said, often these are not enough. I use these pliers to get the rings separated, and somewhat lifted and then insert a thin flat bladed screw driver under it and use that to get the ring pried out of the recess. Highly advisable to get a set of Mac VP's modified lock rings which allow the plier to actually grab the ends. Good luck. It can a be a very frustrating task getting these out on the first shot. |
Rockfla; Do as Tim suggests. Then before reinstalling, grind one of the snap ring bevels
to create a bevel that the snap ring pliers will "catch". I think I saved a few of those snap rings so, if you need one let me know and I'll mail it to you - no charge. |
Thanks Tim & Jim, Mac doesn't currently show his pliers on the web store but I have a few other parts I need for my shifter SO I will ask him when I call in my order. Thanks again
Robert:
Do a little research regarding price. Lang makes high quality tools and you can get them fairly cheaply from on-line tool retailers. Here is what I found with a quick Google search: https://www.summitracing.com/parts/l...xoC-9EQAvD_BwE |
Ever stop to think and forget to start again? |
I pry one end of those bastards out with a small screwdriver and after removing, then grind the one end so you can use regular snap ring pliers.
Doublepumper
I was thinking about sticking (or wrapping) a piece of machinist role (old croakus cloth) around the one side. Same principle as the clover compound. |
These are Wilde who makes the snap on version of the same. I own several of them wilde and snap on. compared to lisle, and others these are the best I have found. The job is still not a breeze, but again the best I have found. I am a tool hoarder. and have stumbled upon many unknown brands that make unusual useful tools.
Thank you very much Michael, I have two different pair of them coming now!!!
Yes, thank you. These seem stouter than the CM's ones I have. Like you, now I need these. LOL
#13 |
#14 |
Just for the comparision to show much much the snap on name adds to the price.
https://shop.snapon.com/product/Snap...g-Pliers/SRP2B |
#15 | |
#16 |
I bought my Snap-on ones second hand, they still look like new and have excellent grip so must be made from good steel. I have ones from MAC tools that look good but do not actually hold well at all, thus the Snap-on pair. For $20 the Wilde ones are worth a shot but if they stink know the Snap-on wont let you down.
#17 | |
#18 |
I would not be surprised if the SO pliers are made be Wilde. Mostly sockets and wrenches are priority to SO and made in house. Other consumables are made by other companies for SO like beam torque wrenches, some pliers, etc.
#19 |
I have always had better luck with my Snap on snap ring pliers. I own several different manufacturers but the Snap on ones are the best.
#20 |
Snap on rebrands the wilde...so unless you have a so truck stopping by to replace/repair tools they are not worth their 100000000% markup.
