Old 01-23-2026, 12:17 PM   #21
nkaminar
nkaminar's Avatar
Default Re: How to be safe driving your Model A
Just now a semi truck ran the red light as I was turning left. He was going 55 mph. I was driving my modern pickup and had my left foot posed above the brake pedal. I was able to stop in time to keep from getting hit. Scary. This is the first time I have seen a semi truck run a red light. Usually the professional drivers are better than that.
Old 01-23-2026, 01:34 PM   #22
The Geezer
The Geezer's Avatar
X2, I used this unit from Amazon. My flashing amber color light attached to the top of my spare tire. It has successfully kept tailgaters back, in addition to a "SLOW VEHICLE" red/orange triangle sign attached to the back of my trunk.
https://www.amazon.com/4-5-30V-10Amp...+Normally+Open
“Finally driving a car older than me!”
The Geezer is offline   Reply With Quote
Old 01-23-2026, 04:04 PM   #23
Bruce of MN
Bruce of MN's Avatar
Check your state laws. This from 45+ years ago, but in Indiana, the triangle could only be used on vehicles going very slow, maybe different now.
Old 01-23-2026, 07:19 PM   #24
IDSpud
IDSpud's Avatar
I agree with Paul & old31...
On a more serious / safety note, I like the idea of a amber or red led light in the back. Having ridden a bike to work often in nice weather (before I retired), flashing lights front & rear gave me somewhat of an advantage making drivers notice more.
Jim
1929 Fordor Leatherback
IDSpud is offline   Reply With Quote
Old 01-23-2026, 09:32 PM   #25
David in San Antonio
David in San Antonio's Avatar
The Geezer - What does the flasher unit do?
I’ve seen some center-high mounted-signal-lights that start with a rapid on/off three or so times, then solid. Is it this?
Thanks
PS re the triangle - I’ve seen a 3-cylinder two-stroke SAAB with a rear sign: SLOW CAR, SORRY.
Late ‘30 Deluxe "Wretched Roadster"
1931 Slant Windshield Fordor “Earl Gray”
Alamo A’s Club
David in San Antonio is offline   Reply With Quote
Old 01-23-2026, 11:22 PM   #26
Y-Blockhead
Y-Blockhead's Avatar
Thanks
David, see post #14. I linked to the a flasher unit as you describefor my third brake light. Flashes three times, then solid. The speed of the flashes is adjustable.
Old 01-23-2026, 11:24 PM   #27
Y-Blockhead
Here is the link to the flasher that I use. https://www.amazon.com/United-Pacifi...aps,241&sr=8-1
Old 01-24-2026, 11:04 AM   #28
nkaminar
nkaminar's Avatar
A flasher would not have saved my @$$ when the semi ran the red light. The thing that did save it was my ability to stop quickly which was due to me going slow and my left foot posed over the brake pedal. I now look to make sure traffic is stopped in both on-coming lanes. If there are vehicles there then I know it would be impossible for anyone to run the light. There is no separate right-turn lane at that location so no one would be able to go around the stopped vehicles.
Old 02-03-2026, 07:37 PM   #29
Y-Blockhead
I just saw this article on flashing lights and thought I would pass it along. Some members indicated they drive with flashing lights on their cars. Take it or leave it...
https://autos.yahoo.com/safety-and-r...231000515.html
Old 02-05-2026, 01:04 AM   #30
serocontra
serocontra's Avatar
found this one for 6v vehicles.
I installed brake and run light, and turn signals from Logo Lights. but the brake light doesnt come on when hit, dont know why. wrote the company and they never wrote back.
https://www.amazon.com/Pre-Wired-Uni...dp/B0C658NYTK/
Archeo-Tech Priest of the Cult Mechanicus.
serocontra is offline   Reply With Quote
Old 02-05-2026, 10:34 AM   #31
bobv
bobv's Avatar
I have the same, doesn't work and no reply from the seller.
I may try one on a motorcycle and see how that goes.
bobv is offline   Reply With Quote
Old 02-05-2026, 10:51 AM   #32
Albert Roussel
Hi Barners
Try measuring twice and cut once before moving from a light.
Albert Roussel is offline   Reply With Quote
Old 02-05-2026, 11:27 AM   #33
Big hammer
Driving with hazards on , flashing strobe lights , rotating yellow lights , whatever ?! Think your doing something safe ?) how many stories have you here of police , tow truck drivers, construction workers hit and or killed working alongside of highways !! I feel it makes you a target for someone to aim at ! Like putting a target on your back
get a bigger hammer tap done
Old 02-08-2026, 05:14 PM   #34
Ed in Maine
I had just finished the restoration of my 1932 Coupe and was driving the car over to a neighbors house. I was about to take left turn into his driveway with hand signals. The window was down so I heard this car coming up behind me and passing me. I was really lucky, I abandoned the turn and let this guy go past me. GET TURN SIGNALS and avoid left turns by changing your route if possible. Ed
