#21 |
Yes, completely true. There was a 2 1/2" width increase in 1/2, 3/4 and tonner pickups and panels in 1942. Always figured it was because of plywood and drywall. I started my cabinet business in 1983, was buying 30 sheet units of 3/4 birch plywood for boxes, hauling from the mainland by ferry in my '38 tonner express. It made no sense at all, but you couldn't pry that truck outa my grip. I finally settled on a 4x6 on edge against one wheel well. But the sloping load was always a pain in the rear. I finally bought a '47 tonner panel truck. Sight unseen, in Parker's Prarie Minnesota. Was in rough shape, but that didn't phase me a bit. What DID, was that the rear door opening was something like 46"-47". Almost impossible to load and unload. Slide in on a slight tilt, then they'd drop down flat and be locked into place. Imagine unloading that by yourself. Been driving ex govenment DNR HD 3/4 ton 4x4 suburbans ever since. Roll up windows, vinyl floors, no AC. First one had a granny low 4 speed and I just bought it back after 15 years. Can't have too many of those.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#22 |
Spare air-holding truck tires - 6.00 x 20 - aren't easy to come across so I used plywood to create a set of garage "wheels" so I could move my truck chassis around in my garage. I was able to cut four 27" diameter pieces from one sheet of 4'x8' 3/4" plywood.
Not a factory approved accessory, but it got the job done until I got some good wheels and tires.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
#23 | |
Alan |
#24 |
The plywood wheels were actually very strong but I never stressed anything too hard. The truck wheel flanges provided quite a bit of contact surface area for the plywood. It was mostly just to roll the chassis straight out of the garage and then straight back inside.
#25 | |
#26 | |
#27 |
Guys,
Sounds like 1929 has been mentioned as the first use of plywood. I know our 32 truck floor boards are original plywood. Regards, Chris and Cheryl
1932 AAB Truck 1953 Ford Jubilee 1965 Mercury Comet Caliente 1966 Ford F100 2015 Ford F250 SuperCrew Lots of Allis tractors Some Cub Cadets |
