#21 |
I have used 35 pound torque for over fifty years with no problems. While i keep the plane across both manifolds evenly, I torque the inner two first then the outer two and in steps to 35 pounds. I think many torque to 55 pounds because they are the same size as head bolts/nuts. But you are not clamping a head against compression.
#22 |
Anyone know the spec thickness of those washers? I have a couple that are thicker than the rest.
#23 |
Back to the muffler-manifold seal: I use a thin bead of Permatex 80355 Muffler and Tailpipe Sealer. It goes on like toothpaste and dries sort of like cement. Each time you remove and reinstall you need to clean both surfaces thoroughly, I chip away what I can and use sandpaper to smooth out the little bits I can't chip away. On the clamps: I wire brush the interior surfaces of the clamps and then sand to get them as smooth as I can so they will slip over the manifold and tailpipe during tightening. I also use a spot of copper anti-seize on the clamp bolts.
I loosely install the tailpipe in the rear clamp, then lift the muffler with a floor jack and gently rock it into position dry. Once in position I drop it slightly, wet the muffler and the manifold sealing surfaces, apply the goop to the muffler, gently lift and squeeze the joint, wipe the excess and apply the clamp. Tighten and pin the rear clamp and it's ready to run.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan (under reconstruction) 1931 Briggs S/W Town Sedan It isn't a defect, it's a feature! |
#24 |
#25 | |
Anyone else want to take a sample? |
#26 |
#27 | |
#28 |
This slide shows how the concave washers are installed on the manifolds. I made this slide just for you all.
Bob Bidonde |
#29 |
The concave washers also work as a bridge to even out slight differences in the thicknesses of the manifolds. The washers will cock slightly to accommodate the flanges being slightly out of plane.
#30 | |
Maybe check w/your supplier, see what they have to say about them.
#31 |
I think this function is more significant than any “spring” they may add to the connection. If “spring” was the desired effect we would use cut lock washers. And note that it’s the backs of the flanges that NK is talking about, these will not compensate for the front (sealing surface) being out of plane since the two manifolds are a bolted assembly.
#32 |
Deleted - duplicate
