Old 01-08-2026, 11:37 AM   #21
JRrev
JRrev's Avatar
Default Re: Manifold Replacement
I have used 35 pound torque for over fifty years with no problems. While i keep the plane across both manifolds evenly, I torque the inner two first then the outer two and in steps to 35 pounds. I think many torque to 55 pounds because they are the same size as head bolts/nuts. But you are not clamping a head against compression.
JRrev is offline   Reply With Quote
Old 01-08-2026, 12:08 PM   #22
alexiskai
alexiskai's Avatar
Anyone know the spec thickness of those washers? I have a couple that are thicker than the rest.
Old 01-08-2026, 12:57 PM   #23
JayJay
Back to the muffler-manifold seal: I use a thin bead of Permatex 80355 Muffler and Tailpipe Sealer. It goes on like toothpaste and dries sort of like cement. Each time you remove and reinstall you need to clean both surfaces thoroughly, I chip away what I can and use sandpaper to smooth out the little bits I can't chip away. On the clamps: I wire brush the interior surfaces of the clamps and then sand to get them as smooth as I can so they will slip over the manifold and tailpipe during tightening. I also use a spot of copper anti-seize on the clamp bolts.
I loosely install the tailpipe in the rear clamp, then lift the muffler with a floor jack and gently rock it into position dry. Once in position I drop it slightly, wet the muffler and the manifold sealing surfaces, apply the goop to the muffler, gently lift and squeeze the joint, wipe the excess and apply the clamp. Tighten and pin the rear clamp and it's ready to run.
JayJay
San Francisco Bay Area
1930 Murray Town Sedan (under reconstruction)
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 01-08-2026, 01:58 PM   #24
Benson
I measured several originals:
.200 to .215
some old rusty repros have slightly larger OD and .185 thick.
Old 01-08-2026, 08:12 PM   #25
alexiskai
alexiskai's Avatar
.200 to .215
OK, if we are measuring at the edge of the washer, out of 10 manifold washers that looked potentially original, I had one that was .215" and every other one was thicker than that. Most were around .250 and the thickest was .289.
Anyone else want to take a sample?
Old 01-08-2026, 08:20 PM   #26
Bill G
Bill G's Avatar
I used to have a 1978 Ford F250 with a six cylinder which also had the cupped washers on the manifold. I think they were maybe a little smaller, but I don't have the P/U anymore to check.
Old 01-09-2026, 08:03 AM   #27
Bruce of MN
Bruce of MN's Avatar
I measured a couple that I assume are original at .285".
Old 01-09-2026, 09:15 AM   #28
Bob Bidonde
Bob Bidonde's Avatar
This slide shows how the concave washers are installed on the manifolds. I made this slide just for you all.
File Type: jpg Manifolods Concave Washer Installation akb.jpg (66.3 KB, 20 views)
Bob Bidonde
Old 01-09-2026, 10:13 AM   #29
nkaminar
nkaminar's Avatar
The concave washers also work as a bridge to even out slight differences in the thicknesses of the manifolds. The washers will cock slightly to accommodate the flanges being slightly out of plane.
Old 01-09-2026, 10:27 AM   #30
katy
katy's Avatar
Originally Posted by Bruce of MN View Post
Our thick ones https://www.snydersantiqueauto.com/p...9407&cat=41733 are spring steel? I'm no expert, but they sure look like more ordinary steel.
Take a file to one and compare it to an regular flat washer.
Maybe check w/your supplier, see what they have to say about them.
Old 01-09-2026, 10:48 AM   #31
JayJay
I think this function is more significant than any “spring” they may add to the connection. If “spring” was the desired effect we would use cut lock washers. And note that it’s the backs of the flanges that NK is talking about, these will not compensate for the front (sealing surface) being out of plane since the two manifolds are a bolted assembly.
JayJay
Old 01-09-2026, 11:26 AM   #32
JayJay
Deleted - duplicate
JayJay
