what autolite spark plug is the best one for a 1953 flathead ? Thanks
I didn't mention its a v8 with Offy heads
Get one that has the correct "reach" so the tip isn't buried in the head.
If they are older Offenhauser heads, there may not be a direct fit plug available. There was a long discussion on here that came to the conclusion that a spacer will be required on the older Offy heads. Start with this thread : https://www.fordbarn.com/forum/showt...ht=offenhauser.
Also, it's probably not a good idea to get hung up on brand loyalty where spark plugs are concerned. Your "favorite brand" may not have a properly fitting plug available. |
i always run champion H- 10 in my 50 cpe 26 years and never had a problem with them good luck
#7 | |
It's not that lots of people haven't done it; I'd say the majority of used heads I have come across have the bottom 2-3 threads all carboned up. It's just not correct. Most use 7/16", 1/2", or even 3/4" reach plugs. Last edited by tubman; 01-05-2026 at 12:41 PM. |
i’m going to have to read the article better before putting my two cents worth i didn’t read the part about offy heads sorry about that i’m 74 now and i think i had that same problem in grade school
