#21 | |
https://alternatorparts.com/how-to-i...lternator.html Thankx for the help.. |
#22 |
Look again, I doubt it is 10 amp, smallest I've seen is 40 amp
#23 |
Probably a casting number ( looks like it says 10 A to these ole eyes ) or series number? of some sort, having nothing to do with amprege rating..
#24 | |
Super Moderator
As a general rule (there are of course exceptions) raised numbers are nearly always casting numbers. Recessed numbers are nearly always identification numbers.
#25 | |
Thankx Joe |
#26 | |
#27 |
[QUOTE=Gene1949;2427672]Gee wizz guys, give the man a break. Nobody really cares who is the better “purist”. He asked a simple question.. Anyways,
I would wire it correctly according to GM. The 1 wire does work but you will be a lot happier with the idoit light and sensing wire setup. Lot better performance at low RPMs like our flatties run. Also install the smallest pully you can find. That also helps at low rpms. I'm with Gene, post 18. BFD if it's not 'purist'. And, I would wire it, like Gene said, per GM. Screw the one wire deal. Only the crowd with sanitary/sterile engine bays worship the one-wire nonsense. As for a replacement, any counterman should be able to solve that. If nothing else, just say 73 Chevy Impala 350... or whatever. If I were close, I'd be happy to assist. I'm sure my stash has a few working alternators of that variety. (And, stash has enough parts to fix any possible problem that your alt has.) Just sayin..... (just for the record, and obviously OT, the last few conversions I've worked on, I used a FORD alternator, no matter what the engine was. I think the Ford alternator has a slightly cleaner-looking case. Something about a GM alternator, under a Ford hood, just doesn't look right to me. I have especially noticed this on Model A bangers. And yes, I've used the Ford alternator on top of a Chevy engine, in a Ford.) (Currently working on a 41. Torn between using a generator, or alternator.... on flathead engine.) |
#28 |
What voltage output do you get if you push a small screwdriver in the D shaped hole as shown in the # four picture (11 o'clock position). By using the small screwdriver to ground the regulator tab you bypass the regulator and are checking the max output of the alternator.
#29 | |
Off to the next problem….. Thank You for your input… |
#30 |
Joe, to test your alternator using a DC voltmeter or multimeter connected to the main alternator battery terminal. No good testing at idle, you need some revs up say around 1500 RPM and you should read at least 13.5 to 14 volts. Do that and report results back to me. Regards, Kevin.
#31 | |
I only checked it at idle and at the battery itself ( battery in the trunk ) , reading 12.20 VDC. With idle and headlights on 12.04 VDC at brand new battery. Last edited by Bazooka Joe; 12-15-2025 at 09:05 PM. |
#32 | |
[QUOTE=bobH;2427744]
#33 | |
Anyways, I ran the chebbie alt for many year until my hearing loss became bad enough I couldn't hear the stereo very well. Replaced the 10si with a Ford Taurus 130 amp. Pure economics. $6000 for hearing aids OR 1200 dollars for kick ass speakers and an 800 watt amp
#34 | |
Off to next project, R&R non functional vacuum wiper and going 12 VDC electric wipers. Thankx for the advice…. |
#35 |
Recommend Newport Wipers for your conversion. JMO
https://newportwipers.com/product/1940-ford/#switches
#36 |
back in my day working for the cadillac dealer i rebuilt lots and lots of those alt.the amp number is stamped where the adj. bolt is it will read like 63 A. or 85 A and the other numbers will give you what your looking for hope this helps
#37 |
the numbers are on the top of the case that bolts to the front housing right behind the adj. bolt i could see it on the one picture you sent but it was upside down and couldn’t get my pewter to lock in to see it but if you have it working by cleaning the terminal great easy fix
#38 |
#39 |
I changed my 46 pickup to 12v, but only cause I got a real hungry 12v winch on the back. My young NAPA guy knew exactly which alternator I wanted.
#40 |
I seen a partial number of 61A stamped along with other numbers, so guessing they made them in 61 amps. as well as 63 amps? Anyway I’m all set, Thank You
