Old 11-16-2025, 04:44 AM   #1
German guy
German guy's Avatar
Default modern shocks
My 30 A came with modern shocks and I want to stick with them. The shocks are VERY stiff and abusive on bad roads. railroad tracks, etc. I want to replace them over this winter's down-time. I do not drive aggressively or do hard cornering. Any suggestions on make/model for a softer ride?
German guy is offline   Reply With Quote
Old 11-16-2025, 05:19 AM   #2
Hotrodfil
Hotrodfil's Avatar
Default Re: modern shocks
https://rotoshim.com/
Hotrodfil is offline   Reply With Quote
Old 11-16-2025, 07:33 AM   #3
updraught
updraught's Avatar
I believe the VW bug shocks fit, and especially the Koni ones work well.
Koni made a name for themselves with the Special D shocks on old classic type sports cars.
These usually have very little, to no, compression resistance, and adjustable rebound up to very hard.
On cars with heavy springs, they allow the springs to compress on a bump, and control the rebound, (or letting go) of the spring, to stop that jarring, and give you that Rolls Royce ride. when properly tuned.
Leaf springs have quite a bit of resistance built in, with friction between the leaves, unlike coil springs, and so shouldn't need much compression damping.
updraught is offline   Reply With Quote
Old 11-16-2025, 08:12 AM   #4
Werner
Werner's Avatar
Hallo,
I bought the four ones from Stipes. They work as they should. They can be adjusted precisely.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 11-16-2025, 08:23 AM   #5
Werner
Werner's Avatar
Thefore, the blades are treated with, for example, graphite/MoS2 grease. To protect them from dirt, I then additionally wrapped them with a grease bandage and then in thin, water-repellent shoe leather.
Werner
Citroen 11 CV, 1947
Old 11-16-2025, 09:09 AM   #6
motordr
I’m looking to buy a set of Stipe Shocks, anyone have a set they would sell?
motordr is offline   Reply With Quote
Old 11-16-2025, 10:03 AM   #7
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Hotrodfil View Post
You mention Rotoshim shocks. Is there a waiting list for them or something?
I have never seen them in stock since they were first mentioned on Ford Barn. https://rotoshim.com/store/ols/produ...s-ford-model-a
Old 11-16-2025, 12:55 PM   #8
Hotrodfil
Hotrodfil's Avatar
They’re available and in stock in the UK. Not sure about dealers in the US.
Old 11-16-2025, 01:48 PM   #9
nkaminar
nkaminar's Avatar
Just take the shocks off to result in a nice smooth ride.
nkaminar is online now   Reply With Quote
Old 11-16-2025, 02:02 PM   #10
Y-Blockhead
I have had Stipe Shocks and Spring Gaiters on my '30 Town Seadn now for ~11 years now, still working great. I coated my leafs with Slip-Plate.
Old 11-17-2025, 12:38 AM   #11
Phil Brown
Phil Brown's Avatar
These are the ones that I used, non-gas filled for an early VW bug 1959-1966
They seem to work well and the cost is very reasonable if you don't need to have original equipment
Phil Brown is offline   Reply With Quote
Old 11-17-2025, 11:59 AM   #12
Herb Concord Ca
What did you do for mounting brackets, make your own or?
Herb Concord Ca is offline   Reply With Quote
Old 11-17-2025, 09:54 PM   #13
gilitos
gilitos's Avatar
I've got a great set of tube shock mounts available. PM me and I'll send pics.
gilitos is offline   Reply With Quote
Old 11-18-2025, 01:08 PM   #14
Phil Brown
Phil Brown's Avatar
Original post said that they were on the car when he bought it. Mine I made up the brackets needed with some early f-1 truck mounts in the front
Old 11-20-2025, 05:02 PM   #15
headonz
headonz's Avatar
Phil , thanks for posting the vw shock info , this was exactly what I had been searching for.
In the last photos showing the front shock ,how is the bottom attached to the axle ? I cant quite make out.
Is this work on the same "A" as in your profile pic ?
headonz is offline   Reply With Quote
Old 11-20-2025, 08:47 PM   #16
Phil Brown
Phil Brown's Avatar
I made up the attachment points and welded them to the bottom of the axle. There are pre-made bottom mounts that bolt to the bottom of spring perch but that didn't quite get location that I needed.
Yes it is the same coupe
Old 11-20-2025, 09:44 PM   #17
Phil Brown
Phil Brown's Avatar
Here is a pic of the available lower shock mount that uses the spring perch bolt to use modern shocks that a lot of people use
Old 11-21-2025, 01:35 AM   #18
headonz
headonz's Avatar
Phil , thanks ,thats just what i want.
I hope to see some build updates of your coupe as you go along ,pictures are worth a thousand words
Old 11-21-2025, 02:17 PM   #19
30Murray
I could be mistaken, but it was my understanding that the stock spring perch bolts are not long enough to mount these. There are longer perches available (Pete and Jakes) but they don't accommodate the mechanical brake actuating arm so would normally be used with hydraulic brakes.
30Murray is offline   Reply With Quote
Old 11-21-2025, 04:07 PM   #20
don3527
We have our own shocks custom made and valved for the weight of the model A. They are hydraulic, not gas. The free length is 14-3/8", collapsed is 9-3/4". They are not listed on our website individually but we do have them available. A-18014-A, $28.95 ea. Snyder's
don3527 is offline   Reply With Quote
