Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 10-22-2025, 02:42 PM   #1
KMAC49
Default "41 Ford hood latch
When I hit an abrupt bump such as a manhole cover, uneven lanes, or "expansion strips" on a concrete road, my hood latch releases the hood. Thankfully it stays latched, and doesn't open. Anyone else have this problem, or has seen it? What's the remedy? Thanks.
Kevin
KMAC49 is offline   Reply With Quote
Old 01-24-2026, 11:05 AM   #2
fordor41
fordor41's Avatar
Default Re: "41 Ford hood latch
Check that hood pin is completely latched. Sounds like pin is not dlwn into latch mechsnism to fully latch. Loosen lock nut on the pin and unscrew the hood pin in increments to get it fully latched
fordor41 is offline   Reply With Quote
Old 03-12-2026, 12:52 PM   #3
normren
In many cases the fix is simply adjusting the latch deeper and replacing the latch spring so bumps can’t jar it loose.
normren is offline   Reply With Quote
