Old 10-07-2025, 11:24 AM   #1
Shoebox
Shoebox's Avatar
Default Metric Ring Sets
I feel the need to ask my Dumb Question of the day. Regarding metric ring packs for the V8s, is what's metric the ring widths- 1.5, 1.5, and 3.0, or are the bores going to be metric, not the usual .030, .060, etc, over bores? I suspect I know but have to ask. Thanks.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 10-07-2025, 12:10 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: Metric Ring Sets
Ring width. Building a 4.250 stroker with metric rings as we speak.
Old 10-07-2025, 12:43 PM   #3
Shoebox
Shoebox's Avatar
OK, glad I asked. What did you take the bore out to and whose pistons did you use? Thanks Tony.
32 Ford roadster
39 Mercury Towncar
Old 10-07-2025, 02:03 PM   #4
KiWinUS
KiWinUS's Avatar
3 5/16 bore. Ross. Waited almost 5 months to have them made.
Old 10-07-2025, 02:42 PM   #5
alchemy
alchemy's Avatar
Are there spacers to use metric rings in a standard groove?
alchemy is offline   Reply With Quote
Old 10-07-2025, 05:11 PM   #6
Shoebox
Shoebox's Avatar
A bit of a wait for sure, but isn't great they can make what you ask for?
32 Ford roadster
39 Mercury Towncar
Old 10-07-2025, 07:34 PM   #7
deuce_roadster
deuce_roadster's Avatar
They have way less friction and seat almost immediately. I have the in all 3 of the engines I built, and they are in the Ardun engine in the car I bought.
Old 10-07-2025, 07:42 PM   #8
big deuce
big deuce's Avatar
The circle track guys use a 1mm, 1mm, 2mm packs. Engine builders claim they hold their shape to the bore very well. Don't know if they are available for flathead pistons in those thicknesses, but probably in the 1.5,1.5,3mm sets. It would take a piston special made with that ring gland. Bored & Stroked could chime in, I believe he uses them from Ross.
big deuce is online now   Reply With Quote
Old 10-07-2025, 10:04 PM   #9
GB SISSON
GB SISSON's Avatar
Still don't understand about metric ring packs. So now Shoebox doesn't have to be the 'dumb question guy', as I still don't get it. Are they thin rings stacked up in the lands? But they'd still need to be sized for our bores.
Old 10-07-2025, 10:12 PM   #10
big deuce
big deuce's Avatar
It's the thickness... you need special pistons to accept the thinner ring gland.
https://www.dragzine.com/tech-storie...-piston-rings/
Old 10-07-2025, 10:33 PM   #11
big deuce
big deuce's Avatar
Another good thread...
https://www.fordbarn.com/forum/showthread.php?t=263235
Old 10-07-2025, 11:14 PM   #12
petehoovie
petehoovie's Avatar
Old 10-07-2025, 11:26 PM   #13
GB SISSON
GB SISSON's Avatar
Thanks for those links Big D, I have now entered the 21st century on the use of metric and thin ring packs. With my 40 mph speed limit here I still feel ok with the cast iron hastings in my recent 276 build, but those are some sizeable advantages I just read about. Yes, 7.5 hp for 200 bucks coupled to less wear is a winner.
Old 10-07-2025, 11:26 PM   #14
cas3
Less friction drag is the point, no?
Old 10-07-2025, 11:58 PM   #15
GB SISSON
GB SISSON's Avatar
Little less weight for the inertia change up, less wear on parts because of less drag too. Worth reading.
Old 10-08-2025, 12:03 AM   #16
big deuce
big deuce's Avatar
They stay conformed to the bore better too. I have only heard about them used in performance builds, no idea on longevity as in 10s of thousands of miles. The wait time will probably discourage most.
Old 10-08-2025, 12:42 AM   #17
petehoovie
petehoovie's Avatar
3 ring pistons as well...less drag...
Old 10-08-2025, 05:32 AM   #18
38 coupe
38 coupe's Avatar
I am very skeptical there is much of any horsepower to be had below 3,000 rpm from metric rings in a flathead. The Engine Masters show did a back to back dyno comparison where they took a small block, tested it, swapped otherwise identical pistons with metric rings, and tested it again. There was no measurable difference below 4,000 rpm. For members who want the most out of their engine way up in the rev range, then metric rings are an improvement. For members who don't drive that fast, or who like me who install overdrive and simply up-shift, there is little point to spending all the extra money.
Here is the link to the back-to-back standard vs metric ring test video, nice comparison graph is at 8:40 in the video: https://www.youtube.com/watch?v=-29IWc-zrv8
Old 10-08-2025, 07:06 AM   #19
tubman
tubman's Avatar
You only need to run the top 3 rings on 4-ring pistons. I've done it a couple of times with no problems. Current (hell, 50 year old) ring technology has made the fourth ring superfluous. Also, the extra cost and trouble running metric rings aren't worth it unless you're seriously into racing. If I had extra time and extra money, I'd run 'em, but everything seems to be in short supply today.
Old 10-08-2025, 09:46 AM   #20
Bored&Stroked
Bored&Stroked's Avatar
What is also important is to consider the diameter of the metric rings - before you bore your engine or order pistons. I typically determine the bore diameter that corresponds to the available ring diameters and ring types I want to use, then custom order my pistons. If you speak with the application engineers at the piston manufacturer, they will be able to tell you which types of rings they can supply for a range of diameters.
Sometimes the diameters align fairly well with what we're used too ---> 3 5/16 for example --> 3.3125. is pretty close to 84 mm -> 3.307 or 84.5 mm -> 3.327. Depending on the ring manufacturer, they may supply rings that are millimeters in thickness, but with inches-based diameters.
One of the nice things about looking for rings first is that you may find a ring package that gives you an overbore that is less than you would have had with typical inches-based ring packages:
Example: 85 mm -> 3.346 inches. This is about 1/2 way between a 3 5/16 bore and a 3 3/8 bore.
Also, there are many types of ring packages --> cast, steel, moly coated, gapless oil rings, etc.. There are many ring options if you look at catalogs and associated applications --> street, performance, boosted, racing, etc..
Here is a Total Seal catalog - has some good information:
TotalSealRingCatalog.pdf
