Old 10-18-2014, 02:00 AM   #1
fordson
Post Correct Tack Strip for 33 / 34 Ford
I have trouble finding the correct 1933 / 34 Ford reproduction tack strip.
My roof area has a recessed gutter type rail, the tack stip fits into (pic. 1). The original style tack strip was rather flat, with a profile that would fit in there (pic. 2).
The reproduction tack strip (pic. 3) however has a profile that does not seem to fit into the recess area, but rather lies on top of it . Thus the roof section will be too high.
I found the 32 reproduction tack strips profile to be more correct (pic. 4 and 5), would that be an alternative ?
Last, i found a type tack strip that has the correct profile, but where the rubber seal slides over the the tack strip acting like a cover ( pic. 6 , 7 and 8). I do not know who produces these, since this kind of strip was featured in an article.
Does anybody know what reproduction tack strip has the correct profile / shape for my car ?
and most important where to get it from ?
Thank you for your help,
Randolf
fordson is offline   Reply With Quote
Old 10-18-2014, 04:50 AM   #2
rich b
rich b's Avatar
Default Re: Correct Tack Strip for 33 / 34 Ford
The parts you show in pictures 3,4, and 5 are finish strips that go on after the top material. The strip with the cover in final pictures looks similar to the stuff sold by Juliano's. Can't really tell from picture 2 if it is the OEM tack strip or a replacement from the past.
The original tack strip was steel incased (open on top) fibrous material that sat in the channel and was almost level with roof, the top material was tacked down, the final trim as shown installed, and then a rubber strip was pressed into the groove.
Old 10-18-2014, 08:09 AM   #3
Uptown83
Uptown83's Avatar
I agree you are showing two different products. The aluminum channel in your 2nd one down or top row to the right takes a rubber gasket in the middle. This is used to finish the top going over the tack strip.
On my 35 I used a plastic mold I pour into the channel for the "Tack strip" My intentions were to use nails in it but after messing with it for awhile I went ahead and used small screws which actually went all the way through the metal. There may be better ways of doing this. But you need to put something to fill in the height.
Uptown83 is offline   Reply With Quote
Old 10-18-2014, 10:50 AM   #4
Andyr
FYI........if you reference the 33/34 Restores Guide , the tack strip should be painted the body color...... thanks....
Andyr is offline   Reply With Quote
Old 10-18-2014, 11:29 AM   #5
DavidG
DavidG's Avatar
fordson,
Your top row of photos has the correct original mouldings for the top insert. The one in the first photo was originally riveted to the channel in the body and was painted as part of the body assembly. A layer of sealer existed between it and the body. It was originally completely filled with tacking material (LeBaron Bonney offer a plastic substitute that will serve as an excellent substitute for tacking. A layer of canvas was tacked to this material; the padding then lays on top of the canvas. The outer roof material is then tacked all around into that tacking strip.
The moulding material shown in the third photo in top row is correct for a '33-'34, not the narrower moulding used on '32s. This moulding goes over the tacked down top material to hide the tacks. It is either tacked in place (as original) or you can use small (#2 or #3) screws to avoid chipping the paint on the outer moulding. A rubber insert then is installed in the top channel to conceal the tacks or screws. (Available from Dennis Carpenter and likely other vendors).
With all due respect to the Club's '33-'34 book, the top inserts were installed in bodies that were already in final paint. From assembly and cost points of view it makes no sense that the outer moulding be anything but black to match the top insert material. I verified that with several Ford archives photos of '33-'34 closed cars with light-colored bodies and in each instance the outer moulding is obviously black.
Be sure and use sealer both before and after installing the outer top insert material and then again under the outer moulding.
Old 10-18-2014, 06:49 PM   #6
fordcpe
fordcpe's Avatar
Here is picture of my 34
fordcpe is offline   Reply With Quote
Old 10-20-2014, 06:15 PM   #7
fordson
Post Re: Correct Tack Strip for 33 / 34 Ford
Thanks David, once again excellent information !!
Thanks for all the answers and suggestions.
fordcpe: How come your one is black and not aluminum colour ?? Painted black ??
From the answers, i understand that:
1) the channel in the roof is to be filled level with the sealer / plastic substitute from Le Baronneys.
2) Canvas covers the chicken wire and extends to the channel, beeing tacked.
3) Padding on canvas and black outer vinyl cover to be exended to the channel
4) Aluminum molding gets placed and screwed / tacked ontop the sealer filled channel. Basically sandwiching the canvas and outer black vinyl cover.
It should look like this then, either in aluminum or ( originally) painted black:
Old 08-12-2025, 05:34 PM   #8
Money Pit
I am also in need of this tack strip. If anyone can help me out I would really appreciate it.
Max Hoyle
Money Pit is offline   Reply With Quote
Old 08-12-2025, 08:17 PM   #9
Lawson Cox
Lawson Cox's Avatar
Wazzup? I don't see no stinkin' pictures. Not nary a one.
Old 08-12-2025, 09:13 PM   #10
petehoovie
petehoovie's Avatar
Old 08-12-2025, 09:24 PM   #11
petehoovie
petehoovie's Avatar
Check with C.W. MOSS @ https://cwmoss.com/products/metal-to...-34-closed-car
Their online ad says "Sold Out" at this time but call them anyway.
Old 08-13-2025, 12:38 PM   #12
Money Pit
Thanks. I checked with C.W. but he doesn't have anything. If you hear of one, I would appreciate it if you would let me know.
Old 08-14-2025, 01:55 AM   #13
Manuel
There are no pictures in the first post. Not on my computer anyway.
Manuel is offline   Reply With Quote
Old 08-14-2025, 06:36 AM   #14
Mart
Mart's Avatar
I can offer an alternative suggestion.
On my 32 Sedan I tried to use the aluminium strips like in the CW Moss pics. I decided they did not fil well, as stated above they do not lay flat.
I bought some rubber strip from ebay. It is self adhesive but I went belt and braces and used some sealant / adhesive under it and stuck it on it looks great and had many comments about it amongst other 32 owners at a recent meet.
I'll show a picture of the product. It is very generic so should be available where you are.
I'll also give a link to my video showing it being fitted.
Not original but looks good and is better than the difficult to use and also non correct aluminium strip.
Video: https://youtu.be/8V_uW4qAJxY?si=olRZqX85_Xpvrb9j
Old 08-14-2025, 10:35 AM   #15
petehoovie
petehoovie's Avatar
