Old 07-05-2025, 03:44 PM   #1
miwi
miwi's Avatar
Default Starter identification needed
I hope that someone could help.
We had found a few starter that together with a Model A project car. Two of them are Model A 4 engine, but there are two other starters that looks the same as the Model A starters. But there thread of the shaft where the Bendix drive is as a different direction.
The Model A starter are left handed, while the others are right handed. All starters have a 3 bolt pattern, the body has the same length and diameter and they are all 6 V.
We are a bit concerend if the two right hand thread are for a Model A engine.
We were thinking that the position of the starter is different on these engines. But why and where were such engine were used?
Thanks for your help
miwi is offline   Reply With Quote
Old 07-05-2025, 03:49 PM   #2
miwi
miwi's Avatar
Default Re: Starter identification needed
These are the stock Model A starters except the one in the middle
File Type: jpg C058F0E4-B567-4313-AB7E-D7C28DCA586C.jpg (56.9 KB, 29 views)
File Type: jpg DDA81BB6-0260-404C-993B-153DCBABB5F9.jpg (187.2 KB, 53 views)
File Type: jpg BB5A5465-87C3-4BF8-AFE8-B9F277A3B28F.jpg (189.1 KB, 27 views)
Old 07-05-2025, 04:09 PM   #3
fordfarm
I have been told the right handed thread is for V8
fordfarm is offline   Reply With Quote
Old 07-05-2025, 05:09 PM   #4
Bob C
The middle one is V8.
Bob C is online now   Reply With Quote
Old 07-05-2025, 06:30 PM   #5
Big hammer
The two on the ends do not have screw holes for a starter switch ! They would fit something later that used a starter solenoid !
get a bigger hammer tap done
Old 07-05-2025, 07:43 PM   #6
Bob C
Good eye.
Old 07-06-2025, 09:19 AM   #7
katy
katy's Avatar
I don't remember specifics, but the Model T starter mounted behind the flywheel, requiring it to turn opposite direction than a Model a starter, so the bendix drive had opposite threads. Prior to 1919 Model Ts only starter was the hand crank.
katy is online now   Reply With Quote
