Question to the group here.
I am planning on getting the cast drums for my car. My question is, where/how do I get the lugs swedged into the new drums/hubs. I do not have a press, nor do I have access to one that I can think of. Could I possibly order from my normal supplier (Snyders) and see if they can swedge them in for me? Dave
--------------------------------------- 1929 Model A Tudor - "Darla" '29 Model A: Old enough to start with a crank, young enough to steal the show! "Stay away from negative people, they have a problem for every solution" Model A Ford Club of America Model A Restorers Club Motor City A's Club |
You can purchase cast iron drums with hubs already installed. Consult your local Model "A" sop / parts dealer.
Bob Bidonde |
Give Randy a call. He is the Model A brake expert. His pricing is also very good.
Randy Gross Brake Drums, Brake Shoes, Wheel Hubs, and Steering Box rebuild 714-292-8660 [email protected] |
I worked on a car that had a couple of the studs tack welded in. Of course they were loose. So I had to have new studs pressed in. I bought the right tool and found a local auto parts dealer who had a shop in the back with a press large enough to do the job. I forget how much force is needed but it is on the order of 8 tons. Your best bet is Randy Gross as Dick M said. He can turn the drums and fit the shoes too.
My 12 ton press worked, put an impact socket of proper size under the stud to keep from bending the drum.
It's not the destination ,it's the journey . |
#6 | |
Joe K
Shudda kept the horse. |
I did a short video showing how I swedge the studs https://youtu.be/s1pLdra4M0o?si=bBlJ4ScsdJALIUZZ
#8 | |
![]() Quote:
Thanks Bill!
Just don't let this happen to you
