Old 06-17-2025, 08:53 AM   #1
Thomas Sargent
Thomas Sargent's Avatar
Default mitchel overdrive for 40 four door
Has anyone installed the Mitchell overdrive in a 40 four door sedan? Wondering if the floor needs to be cut to provide clearance for the box and where at? Mitchell was not clear on my question, felt no cutting of the floor necessary.
Would hate to impinge on the foot area in the backseat Thanks in advance
Tom
Thomas Sargent is offline   Reply With Quote
Old 06-17-2025, 09:03 AM   #2
mcgarrett
Default Re: mitchel overdrive for 40 four door
I wonder if a Mitchell could handle the additional horsepower and torque of the V8 engine.
Old 06-17-2025, 09:11 AM   #3
Kube
Super Moderator
Kube's Avatar
Tom
No cutting necessary on a '40. The Mitchell is a nice unit that operates smoothly.
Still, unless you are acquiring a known good unit, I'd suggest you find a Columbia.
Not sure what a Mitchell costs these days. A properly built Columbia is around $5k.
Old 06-17-2025, 10:34 AM   #4
Automotive Stud
Automotive Stud's Avatar
They make a V8 model which can more than handle a healthy flathead.
Automotive Stud is offline   Reply With Quote
Old 06-17-2025, 04:48 PM   #5
pistonbroke
The unit is back under the seat not the foot well. The Mitchell cost's less then the columbia and is a easier install. I've had both and like both, but for a new install I'll take the mitchell first any day.
Old 06-17-2025, 05:10 PM   #6
aussie merc
aussie merc's Avatar
least you got a reply been trying to contact for 3 years nothing but crickets thought they went to heaven
aussie merc is offline   Reply With Quote
Old 06-17-2025, 06:41 PM   #7
s.e.charles
s.e.charles's Avatar
Originally Posted by aussie merc View Post
. . . thought they went to heaven
from my understanding that would require the optional "afterburner" rear end; around $7,000 US.
s.e.charles is offline   Reply With Quote
Old 06-17-2025, 07:46 PM   #8
HDowse
HDowse's Avatar
I have the Mitchell 26% unit with the original 4.11 rear end. It was relatively easy to install. I chose the cable shift. The forward edge of the Mitchell is very close to the rear edge of the footwell. Once when I inadvertently hit a deep dip, the rebound caused the edge to hit the rear of the footwell. It would be better 2” further to the rear but it’s OK. The gearing is perfect for NH, 4.11 around town, hills; overdrive on the bigger roads. It’s comfortable going as fast as I want to, around 60, real quiet at 55. Bump those numbers up a bit with the standard 3.78 rear.
HDowse is offline   Reply With Quote
Old 06-19-2025, 08:51 AM   #9
Planojc
Planojc's Avatar
Put one in a 39 Std Coupe and no mod of the floor was needed. Used the cable shift and it worked great. You may ask Steve Mitchell for the length from the front of the gearbox to the banjo and measure on your car to see if you have clearance.
Planojc is offline   Reply With Quote
Old 06-19-2025, 10:35 AM   #10
Brendan
Brendan's Avatar
i think they originally put one in a 1 ton chevy truck with a 454
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
Old 06-27-2025, 07:36 AM   #11
Thomas Sargent
any chance you have any pictures of your unit installed to help me visualize how close the floor step is to the box? Did the cable shift install present any problems? Thanks PS very long lead time, almost one year right now.
Old 06-27-2025, 10:22 AM   #12
ssffnomad
ssffnomad's Avatar
It’s close , but it will fit.
The leading edge of Mitchell Aluminum gear box, is the thickness of a wooden paint stick from the step in the floor.
Stretch
ssffnomad is offline   Reply With Quote
Old 06-27-2025, 10:25 AM   #13
ssffnomad
ssffnomad's Avatar
IMG_8608.jpg.
Only pictures I have available at the moment.
Stretch
Old 06-27-2025, 11:37 AM   #14
petehoovie
petehoovie's Avatar
Originally Posted by ssffnomad View Post
Attachment 568902
Attachment 568903.
Stretch
Old 06-28-2025, 08:43 AM   #15
Thomas Sargent
Thanks all
Tom
Old 06-30-2025, 07:08 AM   #16
Automotive Stud
The installed picture is my car. It's a 47 so floor is probably different.
