Old 06-09-2025, 12:24 AM   #141
GB SISSON
GB SISSON's Avatar
Default Re: 9" rear in a jailbar truck
Originally Posted by Scotty's 52 F3 View Post
The width is the same and the cap diameter is the same but the cap bolt centers are different?
Are we talking cast caps or straps? I'm having a hard time visualizing this. Dang Gary, you're SO close.
On my existing yoke (47 jailbar) there are neither cast caps or straps. They are small u-bolts that my best description is... Picture a piece of 5/16 " rod, like 2 1/2" long. Now thread both ends about 1/2" in. Next pound the center of this rod flat on an anvil. Maybe 1" worth of flat. Now bend it into a u-bolt with 1 3/8" or 1 5/8" centers on the threaded ends. Maybe this description is a 'strap', but on my '92 F350 flatbed the u-joint is secured by an actual strap like small bar stock with a hole at each end and a hump in it. Then allen head cap screws threaded into its yoke. No wonder that old Chinese guy said a picture is worth a thousand words.
Old 06-09-2025, 01:34 AM   #142
Scotty's 52 F3
Scotty's 52 F3's Avatar
I gotcha actually. "The devil is in the details" is another saying that applies. Looking forward to your solution. I always enjoy your threads.
Scott in AZ.
Scotty's 52 F3 is offline   Reply With Quote
Old 06-09-2025, 02:46 AM   #143
Randy in ca
Randy in ca's Avatar
There's at least 3 different pinion yokes (that I'm aware of - maybe more) for 9" differentials. Only skimmed thru this video but it looked like it would help you figure out what you're dealing with in that regard.
https://www.youtube.com/watch?v=xKiokoEYAQA
This seems like the style of u-bolts you're describing - again some differences in the sizes:
Randy in ca is offline   Reply With Quote
Old 06-09-2025, 07:52 AM   #144
GB SISSON
GB SISSON's Avatar
Randy, That is a great piece of information! Really narrows the search. I saw some Ujoints that were 1310 on one cross and 1330 on the other. so that's what I'll look into today. But maybe a 1330 is wider....? Like I mentioned there is a 'big cap' 1310 out there just might be what I need. Last year at this time I had a driveshaft built when I installed the T5 from an S-10. I told the guy I wanted it 'T5' on the slip yoke and '47 ford 1/2 ton' on the rear. So My existing rear U-joint is now a 1310 in both directions. Perhaps instead of a 'conversion U joint' from 1310 to 1330 I need a 1310 that has the 1 1/8" big cap on one cross. Lanny had this 3rd member built as a spare for his race 40 ford race car, so I can't go by make and model while searching for this joint. At first I was searching for a u joint for a 1971 F100, but really, that's just the housing.
Old 06-09-2025, 11:14 AM   #145
GB SISSON
GB SISSON's Avatar
Just got off the phone with Driveline Services in Bellingham. They built my driveshaft last year. Looks like I need a conversion joint. Both are 3 1/4" wide, one has 1 1/16" caps, other has 1 1/8". They have one in stock and should have the the u-bolt straps too. Owner will call and confirm when he gets in. UPS from Bellingham normally arrives next day. This joint is a spicer #5-7439 and the straps are as in the post above 2-94-58x. Hope this helps the next guy someday.
Old 06-09-2025, 01:15 PM   #146
cas3
Wille would say, "on the road again, just cant wait to get on the road again"...
cas3 is online now   Reply With Quote
Old 06-09-2025, 01:35 PM   #147
Lanny
Lanny's Avatar
Hello GB, just a note to say that my '40 Ford coupe race car had a 9" Ford
rear end out of a 1957 Ford pickup and that is what the spare pumpkin
with the 4:1I gears I sold you was. It would fit most all 9" housings, but
there were a few Different Yokes used back in the day...
Give me a jingle GB, If there is any questions I can help with. thx, Lanny
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 06-09-2025, 02:16 PM   #148
GB SISSON
GB SISSON's Avatar
Thanks! The driveline shop called and said they made only four different yoke sizes for the 9" and from my rustic, long winded description of what I was looking for he seemed quite sure he was sending exactly what I'm needing. He already had them boxed up and labeled for Fed Ex
Old 06-10-2025, 12:55 PM   #149
Als48
Was your torque tube length OK GB? Or did it need shortening?
Al Hook
Als48 is offline   Reply With Quote
Old 06-10-2025, 03:21 PM   #150
GB SISSON
GB SISSON's Avatar
Al, Beginning in 1942 the pickups got an open driveline. No torque tube. But in order to address your question, the driveshaft should not need to be altered in this situation. The driveshaft I am currently running was built a year ago to accomodate a T-5 transmission from a chevy S10. This altered the length and type of yoke from stock. Now we deal with the back end. It's hard to measure how far the yoke extends forwards especially on the current stock axle. Then factor in different axle tube sizes to butt tape against. I feel quite confident I am really close to same number and of course slip yoke travel is important to keep in the zone. I won't know for certain until axle is mounted in the vehicle. Fingers are crossed on this one.
Old 06-17-2025, 12:05 AM   #151
GB SISSON
GB SISSON's Avatar
Hoping to start the swap in the morning. A lot had to happen to get the woodie back into my good work bay. Finished the work on the skid steer last week. This week it's been getting that old figurehead project out of my way. The owner is a very busy guy and I need him to make a bunch of decisions about how to procede from this point. Scheduling a trip out here can be difficult. Now I see he's out of state for a month so decided to mount the rotisserie on an old trailer frame I had so she's moveable. I will put her in a shed on the lower property until I have confirmation on phase 2. In the photos she is in 'travel mode'. About a foot lower than working height for better center of gravity. Hoist her up with the overhead winch and put the pins in the top holes and she can rotate 360 degrees. With the old gal outa the way I did a good cleanup and got the other old girl in and jacked up on a pair of large mis-matched jack stands. I wanted front up a bit too so blocked and chocked the front wheels too. I think I have all the needed parts and have loosened and tightened back the u bolts etc for no surprises. I'm sure there will be a few. There always is..... My main hope is for no alterations to that driveshaft. The 4th Of July parade is looming and we have more family than ever eager to be involved. Even my baby sister with her husband, 2 sons and grandchild, all the way from someplace called Brighton on the coast of England!
Old 06-17-2025, 12:29 AM   #152
petehoovie
petehoovie's Avatar
Old 06-17-2025, 08:20 AM   #153
GB SISSON
GB SISSON's Avatar
Thank you Pete! I thought I would note before someone else does that the makeshift jackstand in the foreground is welded onto that old chevy rim.
Old 06-17-2025, 05:02 PM   #154
51504bat
51504bat's Avatar
A Chevy rim painted Ford blue under a Ford? Bound to cause trouble at some point
Old 06-17-2025, 06:01 PM   #155
GB SISSON
GB SISSON's Avatar
So far everything has been coming up roses. Spring perches spot on and about 1" space at slip yoke with full weight on springs. I can now reinstall the brake lines I pre-bent and a friend is due to help with the bleeding. Wife due home in an hour and don't think she's up to it after an 8+ hour day.....
Old 06-17-2025, 06:03 PM   #156
petehoovie
petehoovie's Avatar
Old 06-18-2025, 12:08 AM   #157
cas3
My goodness that rear end all painted up pretty hardly fits the MT Picket program! Just kidding of course, looks great. If you know anybody with a wood shop nearby you could cut a piece of wood the correct length to jamb in between the brake pedal and the seat to bleed the brakes by yourself. Thats how I've always done it, since either I have no friends, or its done when they are all sensibly in bed already. Take your pick
Old 06-18-2025, 09:10 PM   #158
GB SISSON
GB SISSON's Avatar
Now that it's installed I have been noticing that both wheels definately turn in the same direction when I rotate one side while up on the jackstands. From youtube it would appear it is a limited slip differential and where I live I consider that a good thing. I used regular 90-140 gear lube for my test drive about 25 mile round trip to town as it never occured to me it may be limited slip. It runs smooth and quiet down the road (did 50 on some straight-aways). When I got to town and slowly turned into a parking lot there was some shuddering with vibrations back there on slow, tight turns, right or left. When I got home I shot everything with my infrared heat thermometer. Yoke was 120 degrees, tailshaft of the T5 was 115 degrees, drums all around 80-85. That seems perfectly fine. All bearings feel smooth and free. I'm sure all the parts are good, but wondering about the need to add a special additive or a different gear lube altogether. I know almost nothing about limited slip or positraction other than they have a clutch pack of sorts and take different lube requirements. Please school me on today's findings. Thanks, Gary
Old 06-18-2025, 11:14 PM   #159
cas3
Sorry I don't have a specific answer, but yes I know there is a small bottle of special additive to use to make the clutch pac happy. Google 9" ford, there are several places that specialize in 9"ers and I would bet the answer is there
Old 06-18-2025, 11:54 PM   #160
Lanny
Lanny's Avatar
Hello GB, I had bought that 9" pumpkin from a friend who had built it.
I wanted it for a spare for my 1940 race car. I just knew it had 4:11 gears
but never cared if it was limited slip or not. We just raced at the local tracks
with our restored old race cars, mostly for fun and a good time.
Here's a picture of my old restored '40 with 276 flattie with dual carbs.
Click on Pictures to Enlarge.
File Type: jpg Flathead with Merc crank 2 pots, allum heads.jpg (63.2 KB, 19 views)
