Old 05-06-2025, 06:54 PM   #1
1939mars
1939mars's Avatar
Default '40 Mercury rear end
I am helping with a '40 Mercury. The rear axle was partially disassembled by a well meaning but uninformed person that is pretty strong. Strong enough that on the passenger side the axle end is mushroomed over and the drum is cockeyed to the backing plate. I tried my KR Wilson puller and the drum did not budge. We had penetrating oil on it and used a breaker with a 3' cheater. There was so much tension on it that the base of the tool was starting to spread! I am not sure what is bent and damaged in this unit so I am not sure that the tool is going to do its thing.
My question is, does anyone have any ideas aside from heat (my next step) to get this drum off? The drum is destroyed already so I am not worried about damaging it. Whatever I do, though, I do not want to damage the ring and pinion so that the whole thing can be rebuilt with those two existing parts.
Alternatively, does anyone know of a 39/40 Mercury rear axle in the Los Angeles area?
Thanks,
Scott
1939mars is offline   Reply With Quote
Old 05-06-2025, 07:01 PM   #2
Bob C
Default Re: '40 Mercury rear end
Is the hub still good??
Old 05-06-2025, 07:18 PM   #3
1939mars
1939mars's Avatar
Looks to be, yes, but I will not know for sure until its apart
-Scott
Old 05-06-2025, 07:37 PM   #4
ford38v8
ford38v8's Avatar
The ring/pinion will survive, and with any luck at all, housing will also survive, but sounds like the axle bit the dust. KRW puller did it's job, which was to release the drum from the axle. Beyond that, your handbrake was likely set, shoes rusted to the drum, drum ridged from shoes. In any case, the shoes are cocked now and will not recede, will only get cocked tighter the farther the drum moves outward. Nothing to do but the red wrench now. Concentrate on the inner edge of the drum, that's where the shoes are cocked and binding.
BTW, you do know that the pinion is one piece with the driveshaft? Won't transplant to a Ford.
Alan
ford38v8 is online now   Reply With Quote
Old 05-07-2025, 02:19 PM   #5
bobH
Yes, but.... many have been converted by a competent machinist with flathead knowledge. In the past, are sometimes found to have 3.54's, hence the reason to convert them for Ford use. Just saying...
bobH is offline   Reply With Quote
Old 05-07-2025, 02:45 PM   #6
Charlie Stephens
The last time I heard a story like yours it turned out that the axle had safety hubs installed. Any chance that is your problem?
Charlie Stephens
Old 05-07-2025, 03:14 PM   #7
Kube
Super Moderator
Kube's Avatar
Alan, I knew the Merc was one piece but never knew why that was. Do you?
Old 05-07-2025, 03:21 PM   #8
rockfla
rockfla's Avatar
Mike & Alan
The the OP original question in post #1, and I quote "Alternatively, does anyone know of a 39/40 Mercury rear axle in the Los Angeles area?"
There is no difference in the axles between the Mercury & Ford rears is there???
I know about the longer drive shaft/tubes and just learned of the pinion BUT axles???
Old 05-07-2025, 03:45 PM   #9
Charlie Stephens
When checking for safety hubs the first hint is to look for two bolt heads and two studs with nuts holding the backing plate to the axle housing. Ford used four bolts.
Charlie Stephens
Old 05-07-2025, 06:34 PM   #10
ford38v8
ford38v8's Avatar
Originally Posted by rockfla View Post
Mike & Alan
Originally Posted by Kube View Post
Alan,
rockfla, axles are the same.
Mike, the only reason that would make sense is that it was an exercise in cost savings that didn’t make the cut.
Alan
Old 05-07-2025, 07:05 PM   #11
Tim Ayers
To the OP, if not safety hubs, it's possible a broken & chewed up axle key is causing everything to bind up.
With that much torque on it, I would think the flange of the hub is now tweaked a bit. You may have to torch it off and get a replacement axle shaft.
To the one piece driveshaft/pinion, I'm wondering could it be to reduce vibration by not having a coupler in there? Mercury was a step higher end vs. Ford at this time, right?
Just a guess I'm throwing out there.
Old 05-08-2025, 04:59 AM   #12
rich b
rich b's Avatar
Had one that wouldn't come off normally; used an Air Arc to cut a big chunk of the drum off and then cut the hub along the key and across the inner raise until it popped. Axle was not hurt and neither was the bearing.
Old 05-08-2025, 06:56 AM   #13
Terry,OH
Terry,OH's Avatar
Suggest to install the drum puller with substantial pressure and leave it on at least overnight. Check the next day if it is slacken tighten it again and it may come off. Hit the hub with a hammer not to drive it on but to shock it with vibration.
Old 05-08-2025, 07:21 AM   #14
Tim Ayers
Terry & Rich, great suggestions.
Old 05-09-2025, 08:45 AM   #15
jimvette59
jimvette59's Avatar
Use a cut off wheel and cut it in half or until it opens up. JMO
jimvette59 is offline   Reply With Quote
