Old 04-20-2025, 10:58 PM   #1
Tom in TN
Tom in TN's Avatar
Default Engine detailing help
Hey Y’all,
Got a question and maybe the only people that can answer this are those who like to keep a clean motor.
I am running an engine with an aluminum intake and a leaky Holley carb. This combination it has caused gasoline to stain the manifold various shades of brown in places.
I am not going to remove the manifold (but yes, I AM fixing that carb) but I do want to clean the brown stains off it.
So, what product do you use to clean the brown gasoline stains off of your aluminum intake?
Granted, I should have cleaned it sooner rather than let it buildup, but dealing with cancer makes one put off some things.
What is your ‘it works every time’ solution?
Tom in TN is offline   Reply With Quote
Old 04-21-2025, 05:38 AM   #2
NC Plumber
Default Re: Engine detailing help
I would try some oven cleaner. Carefully at first to make sure it doesn't darken the intake.
NC Plumber is offline   Reply With Quote
Old 04-21-2025, 05:57 AM   #3
glennpm
glennpm's Avatar
Oven cleaner attacks aluminum and could turn the color black. I've used paint thinner, mineral spirts with good results.
Glenn
Archives of historical but relevant older articles:
Hover mouse over the links below and click!
Rumble Seat’s Notes
Techno Source for the 1932 thru 1953 Flathead Ford
Old 04-21-2025, 06:35 AM   #4
Terry,OH
Terry,OH's Avatar
See this posting for cleaning cast aluminum.
https://www.fordbarn.com/forum/showthread.php?t=348446
Old 04-21-2025, 06:48 AM   #5
Tom in TN
Tom in TN's Avatar
Thanks fellas
Old 04-21-2025, 07:01 AM   #6
BW
Try Lacquer thinner.
BW is offline   Reply With Quote
Old 04-21-2025, 08:36 AM   #7
51504bat
51504bat's Avatar
Maybe soda blasting?
Old 04-21-2025, 09:22 AM   #8
hotcoupe
hotcoupe's Avatar
To clean aluminum, I always use "Alumiprep 33", or "Bonderite 33". It is 33% phosphoric acid, it CLEANS aluminum, the airplane guys use it.
Tom
hotcoupe is offline   Reply With Quote
