Old 04-15-2025, 12:06 AM   #1
panhead_pete
panhead_pete's Avatar
Default 3.54 ratio stock in an axle
Did any of the V8 banjo rears come stock with a 3.54 gearset?
Thanks
Pete
Looking for an unrestored 33 34 3W or 5W coupe.
Thanks
panhead_pete is offline   Reply With Quote
Old 04-15-2025, 03:34 AM   #2
69a
Default Re: 3.54 ratio stock in an axle
Yes! I'm no expert, but 11-39 is 3.54:1
69a is offline   Reply With Quote
Old 04-15-2025, 05:37 AM   #3
Steves46
Steves46's Avatar
To the best of my knowledge most of the 1946 cars.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 04-15-2025, 06:48 AM   #4
rockfla
rockfla's Avatar
A 3:78 to 1 was offered in 1932 4cyl's and starting in 1934 a 3:54 to 1 was available in both passenger & commercial vehicles.....starting in 1937 3:54's were offered with the 85Hp only....NOT the 60hp.
Old 04-15-2025, 07:18 AM   #5
rockfla
rockfla's Avatar
Sorry for the blurry edge scan but this starts 1932 at the top through 1938
Old 04-15-2025, 07:45 AM   #6
deuce lover
deuce lover's Avatar
I think the OP wanted to know if the 3.54 was factory installed at time of purchase. IMO it was special order or dealer installed.I did at one time in the last century have a 33,34 center banjo section with 3.54's and it was stamped that way from new I imagine.
Old 04-15-2025, 08:44 AM   #7
Elmo Rodge
Elmo Rodge's Avatar
My 1936 Touring Sedan has one. I bought it in Texas in 2003. I'm pretty sure it was never changed, judging from the rest of the car.
Wayno
Life is not a spectator sport.
Elmo Rodge is offline   Reply With Quote
Old 04-15-2025, 09:35 AM   #8
42merc
42merc's Avatar
Many '42 - '48 Mercuries were equipped with 3:54 gears from the factory.
42merc is offline   Reply With Quote
Old 04-15-2025, 04:55 PM   #9
panhead_pete
Thanks all. It would be going under an AV8 so Im open to most years of rear although preferably 39 up for the juice brakes. Will keep my eyes open for 11-39 stamps.
Thanks
Old 04-15-2025, 08:32 PM   #10
alchemy
alchemy's Avatar
39 and up brakes will bolt on to any old Ford rear axles back to the A’s.
alchemy is offline   Reply With Quote
Old 04-15-2025, 10:56 PM   #11
cadillac512
cadillac512's Avatar
My '41 Merc has stock 3.54 gears in the banjo.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 04-16-2025, 07:21 AM   #12
hotcoupe
hotcoupe's Avatar
The backing plates will bolt on to an earlier axle housing, but they may not be clocked correctly ( the wheel cylinder will not be level, making it hard to bleed the brakes). I know '32 - '34 are that way.
Tom
hotcoupe is offline   Reply With Quote
Old 04-16-2025, 02:30 PM   #13
Steve Staysko
Steve Staysko's Avatar
I just had Strong's Garage changed out the 4.10 gear set in my 34 roadster to 3.54 and wow what a difference its a totally different car to drive, at 60 the engine purrs along with much lower rpm.
Steve Staysko is offline   Reply With Quote
Old 04-16-2025, 02:33 PM   #14
rockfla
rockfla's Avatar
Did the same on our 1932 20+ years ago, same report, same results!!
Old 04-16-2025, 09:28 PM   #15
alchemy
alchemy's Avatar
Tom
I have 40 brakes on the stock rear axle in my 32, and they work great. No modifications at all.
Old 04-20-2025, 07:33 AM   #16
38 coupe
38 coupe's Avatar
Be careful with the 39-41 Mercury axles with 3.54 gear sets. The driveshaft and pinion gear are one very long part with no coupler. I have been told you can cut the drive shaft off at the correct length and have splines machined into the pinion gear, but I have never done it myself.
