Texasroadkill wanted a pic or two of my 8NV8. Hard to upload pictures, so little bandwidth, but I'll keep trying.
The tractor is a low hour 1949, The engine is from a '49 truck. The nose may look like a stock 8N, but it has been widened slightly to accommodate a Ford truck radiator. The nose also has a slant to it. The exhaust manifolds are from an industrial engine and modified. We made a foot throttle, much better than a purchased one. Put er in 4th gear, step on it and hang on! I'll have to find another pic that shows her finished. My goal was to create a V8 in what may have been Henry's vision, as it looks very factory.
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe Last edited by TomC750; 02-19-2025 at 11:30 AM. |
A finished pic of my 8NV8. The tractor was completed quite a few years ago and stored since. In the meantime had a number of life's hiccups, so not much time to play with it. Hmm, Found pic but cannot insert image, it wants a URL ?? Previous uploading images went OK.
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe Last edited by TomC750; 02-19-2025 at 04:15 PM. |
Very nice job.
John
Welcome each day |
#4 | |
What kind of speed does it get in 4th gear?
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe |
At least 30MPH, although I have not tried for the max.
Very nice tom. I really want to build one in a few years. Have a few parts 8ns and a few older flatheads sitting around. Looking at the kit, I forget the name at the moment they build thats modeled after the funk kit.
Tom, do you have more photos of your cab over semi tractor in your avatar photo?
30 MPH on an 8N would feel like you are in a top fuel dragster,no?
Better get a rollcage next,
#13 |
And maybe some juice brakes on all four
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
#14 |
How wide are the rear rims? And if you don't mind, how much did the turf rears set you back?
#15 |
Very nice , indeed.
I dig coal, which provides motivation for EVs. |
#16 | |
I tried again, when I hit upload image it looks for URL???
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe Last edited by TomC750; 02-20-2025 at 01:51 PM. Reason: problem uploading image |
#17 |
The turf tires I spent $20 for them, they were nearly new, but my friend did not want them on a tractor he bought. Special circumstance for sure. Unfortunately, I do not remember the rim width. It is possible I have it in a file.
TomC750 1949 8NV8 Ford tractor 1930 1 Ton White 1941 Mercury Sedan Coupe Last edited by TomC750; 02-20-2025 at 02:36 PM. |
#18 |
Found that when I went to "manage attachments" it worked.
#19 |
#20 |
That just makes you smile. I'd love to hear it running.
