Old 02-06-2025, 07:45 PM   #1
oldgas
Default Drainage
I have installed new inner rear Quarter trunk drop-offs,
There is two rubber plugs to be installed in the drop-offs one is a vent & the other is a plug & the location to my understanding is at the front & rear of the drop-off question which on goes were?
Thank you for your time. oldgas
oldgas is offline   Reply With Quote
Old 02-07-2025, 10:28 AM   #2
KULTULZ
KULTULZ's Avatar
Default Re: Drainage
What are you working on?
KULTULZ is offline   Reply With Quote
Old 02-09-2025, 08:35 PM   #3
oldgas
Work on a 1956 Ford Sunliner
Old 02-09-2025, 08:37 PM   #4
oldgas
I'm working on a 1956 Ford Sunliner.
Thank You.
oldgas
Old 02-10-2025, 01:34 AM   #5
KULTULZ
KULTULZ's Avatar
Post Re: Drainage
You are describing the rain trough's that run on either side of the deck lid opening? The MPC shows the troughs but not any plugs.
Are you maybe describing the rear body panel?
Maybe they have something to do with the fuel tank fill and vent?
Can you provide a photo?
Old 02-15-2025, 09:06 PM   #6
oldgas
I have solved were the drain plugs are locates & which one goes were.
Oldgas
