Old 01-28-2025, 01:33 PM   #1
Dorf55
Lightbulb 3 on the tree..going to the floor
I have a 55 ford Fairlane and need to remove the column shifter and put in a floor shift.
What is the simplest and easiest way to remove the shifter tube from the column ? The car and interior are in finish paint.
If I don't remove shifter tube what suggestions do you have ?
thanks
Dorf55 is offline   Reply With Quote
Old 01-28-2025, 01:43 PM   #2
KULTULZ
KULTULZ's Avatar
Default Re: 3 on the tree..going to the floor
The main problem will be the shift lever socket.
As far as I know there is no replacement lever socket like a later floor shift car.
Stripping everything else from the steering column should be simple.
KULTULZ is offline   Reply With Quote
Old 01-28-2025, 08:47 PM   #3
Hot Rod Reverend
Hot Rod Reverend's Avatar
Dorf55, this is what I did with my 1955 Ford Club Sedan: https://www.hotrodreverend.com/post/...n-blog-part-11
To each their own, but when I went with the period Hurst syncro-loc shifter I wanted to not only remove the column shift lever but replace with a shaft. I am very happy with the end result.
Red Lion, Pennsylvania
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 01-29-2025, 10:07 AM   #4
Dorf55
Thanks you !
Old 01-30-2025, 12:22 PM   #5
KULTULZ
KULTULZ's Avatar
Thumbs up Re: 3 on the tree..going to the floor
DAMN (whoops - sorry REVEREND) GOOD MOD & RIGHT-UP!
Much nicer install than flat-rating it.
