On the 32 5W std coupe, I heard non had roll down rear window but I also heard some had it but I read ’all’ had it.
The parts to rolld down the window is that the same as on the A-Ford ? Is handle like a door handle or a wrench. Who make this parts new ? I had try to find the parts but the metal has be rusty and I has not find any Arizona car parts. I try to stay away from China parts and go Henry. If some had the parts contact me private. |
Hi Hank
The roll down rear window was standard on 1932 Ford coupes. Its a rather simple arrangement there's only one arm used under the window channel to move it up and down. The one in the Deuce five window I built for my wife is an original that came with the car. I would think an original mechanism could be found or possibly an original door window mech maybe can be shortened to work. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
Not all 5w coupes had the roll down window. The regulator is a basic model A door regulator. Then you must find the wood frame work. Then the lower metal tray that catches water. The window winder is a T shaped handle similar to 28 up rear window winder.
I has no idea how my body was made but its cool to has it even if my is chopped and a ’race’ car.
I has a pretty good idea how it all is but need to find the parts. I know some told me a company had the metal new made with water channel. It was not Pacific. I might can find a std A-Ford window winder. ————— I’m not shore if this car will has interiour or the textile roof, I might only use the wood open and has the seat in leather. If so its very nice to has Henry wood and the rear widow std steel parts. But I might do a full interiour and then I might copy the old wood ( I has most of it it but 50% is in a bad condtion, burned after chop ) and if interior I can use new steel/crank rear window parts. —————— One thing I learned in this project, is that parts is very expensive ( complex to find ) and my body was empty so its extremly expensive and hard find all parts and bolts ( or how it was made ) Actually its take years and its insane in time/money, plus add I’m a machinist, I cant weld or do metal. I has no space either for steel grinding or paint. So its a fun road but one thing I cant get is that complete cars is not that expensive but parts is insane. -Why, I can get it but it shore was a misstake. People say, ”build build”, but how can I as first I need find my ’style’ then I has no parts, no experiance, no tooling so I’m realy on find craftsman get on further. To be philosofic, guys build this cars back then was not into has it perfect ( far from ) but I like it very nice made in my style. Guess I was real naive get a frame and a emoty body less all kind of experiance on this cars or works or what fits tohetger. |
Here's a link to a Hamb thread where a listing (sold) has pictures of most of the parts you're apt to need.
https://www.jalopyjournal.com/forum/...-sold.1315659/ The regulator is the same as the right door on some model A's. Brookeville lists the parts and wood - not cheap if they're in stock. |
I think it will be hard find this parts, and I did look a fragment here for sale before and crank was rusted up ( must been out for 75 years ) and few come up for sale in US. I guess I need get it new, and I try stay away from Pacific parts and I heard a name of a company sold this parts US made ( forgott brand ) |
Hi Hank
I have an extra original 32 Ford drip pan from a Deuce 5 window. Ronnieroadster
Hank: I got all the parts needed for the roll down window in my 5 window from United Pacific. Back window regulator plate B20218, Back window drain pan B20219, Rear roll down glass channel B20117, Roll down back window regulator B21112, Back window wood assembly B20067, and since I removed the package tray for more leg room, the rear package tray brace B20217. Also the back window crank handle B20140. I used a universal SS spring loaded escutcheon. Everything fit and worked perfectly. Don't be afraid of UP parts, they are top quality parts that fit and work. I've used a lot of their parts in the restoration of my roadster, 5 window and pickup. They are the closest to real Henry parts currently being produced. Gary at Cornhusker
#9 | |
So in starting to make my reply I was going to start with "The back window regulator..." But then looking at the 1938 "Hardware and Trim" book and the photos of the unit sold on the "HAMB" I realized there might actually have been TWO different regulators! The one shown in the 1938 book uses three mount screws, the one on the "HAMB" uses four! The three mount hole regulator (B-48205) is somewhat similar to the "basic model A door regulator" used on coupes, tudors, and pickups (except there are at least two significant variations there). The B-48205 differs at least by having the handle shaft drilled and tapped for the handle anchor screw, using the spring loaded slider at the end of the arm (similar to what is used on Model A fordors and 1932-39 closed cars), and likely a different arm length. The 1929-30 Model A fordor regulator would not have the handle shaft drilled and tapped and the arm length might be different than what is needed for the back window. Another specification that could be important is the length of the handle shaft, too tall and the handle sticks out, too short and the handle gets buried in the upholstery. I know of variances in shaft length between different regulators but I dont know what the back window needs. The sidebar here is the earliest model a used a slotted handle shaft and the door handles were attached using a side orientated set screw. At some point Ford converted to the side drilled handle shaft and the float pin the V8'ers should be familiar with. Brookville makes/made the back window tray. It is a forming rather than a stamping as are the originals or United Pacific reproduction. I have to question whether or not original 5 windows had a fixed back window. My parts selling experience suggests that the window felt has a width of about 11/16", a simple pane of glass with the common rubber seal about 1/2". The implications here have to do with how the upholstery, garnish molding, and window all interface. In order for everything to fit the entire structure of the back of the turret would have to be different, or a special rubber seal (5/8"-11/16" wide with 1/4" glass groove) would have had to have been used. I have never seen any reference to a special seal of this type (EXCEPT on 1936 standard fordor sedan quarter windows). |
#10 | |
"Never complain,never explain"... Henry Ford II |
The best bet would be the United Pacific chrome ones as I think they have the rounded ends as original. Paint them. The stainless/zinc ones are from Brookville. They are a continuous formed strip so do not have the rounded ends, and are tudor sedan length and have to be cut down. Far better than nothing.
Least we forget that the regulators are different for the standard coupe (5W) and the deluxe coupe (3W) such as the referenced one on HAMB. That regulator's part number is B-528400. The former has three attachments and the latter has four attachments. The horizontal glass channel, the glass, and all the surrounding wood work are also unique to each type of coupe.
#13 |
Cast aside my post & opinions. Hank shows a chopped 5 window in his picture above The United Pacific parts are right, fit, are good quality, work and are available. Hank is building a vintage hot rod not a 100 pt. restoration.
#14 | |
Keep your observations alive! While maybe not totally applicable to the OP, they will be of great value to anyone who consults this thread. |
#15 |
Thanks.
Great to has the Pacific partnumber. I might wait to LARS to find some std. But I can live with new parts as described. If anyone read this and has decent complete package I’m intrested. |
#16 |
My apologies for throwing this thread somewhat off line with my post above - I guess my brain was thrown off course by your Fordbarn 3W Hank name and not paying enough attention to the real details!!
#17 |
I checked up the Pacific parts and it's a total at 630 USD.
New parts and guess no fuzz. I might has a 'decent' old plate and I think I can get A-Ford window crank here and handle. I has some wood parts. One thing I notice in the Pacific body was the bar B20217. If my memory is correct I saw a std 5W and it had a package tray so that bar from Pacific is not std, but a deal if some one like to use no package tray - is that correct ? Now I has more on feet on that project. Let's see how I do. I really like get all this parts std Henry aka Arizona car and I'm ready to pay for a good set complete. |
#18 |
The B20217 is a reinforcement piece to help with body strength when removing the package tray. Removing the package tray adds 3-4 inches of leg room. Doesn't sound like much but it makes a difference in comfort on long drives. I like UP parts because they fit, are good quality and I'm not dealing some bodies cast off left overs.
#19 |
I has this parts, so 2 package tray can be one working and its a plate on that to the windowcrank, but the other plate must be behind the wood.
Ex PU B20219. I think I found a decent A-Ford mechanism. The same as coupe 32 ? Also a drawing for A-Ford drain plate ( if that is the same maybe ? Last edited by 3W Hank; 01-27-2025 at 08:20 AM. |
#20 |
This '33 3w has its roll-down w/ Henry's 'safety glass'; i.e., two sheets of plate glass; i.e., Ford Safety Glass Company glass; its clear material glued between the two sheets; termed 'shatter-proof' in Ford ads. (Do read why Henry created his Ford Safety Glass Company because of an accident he had in 1931 during his proud demonstration of the new '31 Model A.
The safety glass company and its building was separate and apart from Ford with employees paid by Ford Glass, although neighboring on Ford property in Dearborn. After creating the safety glass company, realizing that he was thee only auto glass maker in the world, he supplied the safety glass for any and all auto makers on the planet. Replies and if any corrections welcome! Thank You - Last edited by highbeams; 01-27-2025 at 09:10 PM. Reason: addition of Replies and if any corrections welcome! |
