Old 12-15-2024, 11:40 AM   #1
Shoebox
Shoebox's Avatar
Default Idler Gear Removal
I'm tearing down an 8ba block in preparation for a trip to the machine shop, going to see if it's good or a boat anchor. Anyhow, I need to remove the oil pump idler gear, I threaded a bolt into the gear and gave some tugs with my rather small slide hammer..... didn't budge. Just want to verify this is the correct method for removal? Thanks.
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is offline   Reply With Quote
Old 12-15-2024, 11:46 AM   #2
mcgarrett
Default Re: Idler Gear Removal
Best I can remember, it should slide off the shaft using a couple of screwdrivers as levers. While you're at it, check the bushing to make sure it's not worn allowing the gear to rock back and forth on the shaft.
Old 12-15-2024, 11:58 AM   #3
mcgarrett
Correction to my previous post. I seem to remember now that I had to use a larger slide hammer to remove the gear shaft. Apologize for the misinformation.
Old 12-15-2024, 12:01 PM   #4
19Fordy
19Fordy's Avatar
Here's an earlier helpful thread about this gear.
https://www.fordbarn.com/forum/showt...ump+idler+gear
Old 12-15-2024, 12:43 PM   #5
Shoebox
Shoebox's Avatar
I have to thank you, and laugh at myself with you directing me to a thread of MY OWN from 2 years ago when I was facing the installation of said gear. Guess that shows the extent of my memory. Well I need to find a BIG socket or heavier slide hammer. Thanks!
32 Ford roadster
39 Mercury Towncar
Old 12-15-2024, 01:11 PM   #6
GB SISSON
GB SISSON's Avatar
Thanks Shoebox, I can't tell you how much better I feel about myself right now!
Old 12-15-2024, 02:36 PM   #7
Bored&Stroked
Bored&Stroked's Avatar
Definitely a case of "CRS" - LOL
Old 12-15-2024, 03:44 PM   #8
GB SISSON
GB SISSON's Avatar
Dale, is that 'Can't Remember Syndrome'?
Old 12-15-2024, 07:05 PM   #9
Bored&Stroked
Close . . . it usually means "Can't Remember Shxt"
Old 12-16-2024, 03:03 PM   #10
Ronnieroadster
Ronnieroadster's Avatar
To remove that gear I use my KR Wilson tool.
Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block
First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921
First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587
Old 12-16-2024, 03:38 PM   #11
51504bat
51504bat's Avatar
Also a milder version of CRAFT Can't remember a frik'n thing
Old 12-16-2024, 03:42 PM   #12
GB SISSON
GB SISSON's Avatar
Thanks guys, I'll have to remember those acronyms.... Wish me luck.
Old 12-16-2024, 07:18 PM   #13
Shoebox
Shoebox's Avatar
Ronnieroadster
Ya, I've looked all over and can't find mine.
32 Ford roadster
39 Mercury Towncar
Old 12-17-2024, 11:15 AM   #14
Kens 36
Kens 36's Avatar
Simple solution. Buy a new one. The one you already have will appear almost immediately
https://www.nirgv8.org
Kens 36 is offline   Reply With Quote
Old 12-17-2024, 03:17 PM   #15
Gene1949
Gene1949's Avatar
Works every time for me. I shouldn't complain at this point in my life BUTT, was under the 49 doing yearly. Needed a wrench, got out from under, went to toolbox AND WONDERED WHY I WAS THERE... Jeez
Gene1949 is offline   Reply With Quote
Old 12-17-2024, 03:51 PM   #16
34fordy
34fordy's Avatar
Reminds me of my last few years working on fork lift trucks. Working on a truck at my stall with my tools directly behind me, I would turn around to get the needed tool and forget what I was after. I would stand and look into the tool cabinet trying to remember what I was doing to the truck. Many times I had to turn around and see what I was doing to determine which tool I was after. This malady was going on 20 years ago so you can only imagine what I deal with now! LOL NRTF (not really that funny)
34fordy is offline   Reply With Quote
Old 12-17-2024, 04:43 PM   #17
3twinridges
3twinridges's Avatar
The Wilson tool is just a stout cylinder with a bolt to pull that gear. You could probably rig up something with a bar, some spacers, and a bolt to pull it. It’s just pressed in.
3twinridges is offline   Reply With Quote
Old 12-17-2024, 04:59 PM   #18
1952henry
1952henry's Avatar
Have to dig it up, but I made one using part of a Model T running board brace. Worked well.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 12-17-2024, 07:40 PM   #19
Shoebox
Shoebox's Avatar
Well guys, I took this block to the machine shop for hot tank, bake and mag, and decided to "delegate" a couple additional tasks: remove the front oil gallery plug and the idler gear. I have done both before, but this time around I'm going to let someone else have the fun.
32 Ford roadster
39 Mercury Towncar
