Old 12-08-2024, 04:46 AM   #1
danliveshere
danliveshere's Avatar
Default Rpms tire size and different rear axle ratios graph
Guys I seem to recall years ago seeing a graph on here that someone posted that showed the effects of different rear axle ratios , tire sizes and rpm at a certain speed. I can’t find it.
Has anyone got access to that? Thanks Dan
danliveshere is offline   Reply With Quote
Old 12-08-2024, 05:58 AM   #2
danliveshere
Default Re: Rpms tire size and different rear axle ratios graph
I found this over on the hamb
Old 12-08-2024, 07:55 AM   #3
HDowse
HDowse's Avatar
I’ve used this website. Plug in values for tire size, differential ratio, RPM, speed. Plug in any 3 values to get the fourth.
http://www.advanced-ev.com/Calculators/TireSize/
HDowse is offline   Reply With Quote
Old 12-08-2024, 02:22 PM   #4
rotorwrench
rotorwrench's Avatar
If you have the 1950 revision (green bible) of the Ford chassis parts catalog from 1928 to 1948, you will find a basic chart in there for the speedometer drive gearing.
Old 12-10-2024, 07:03 AM   #5
38 coupe
38 coupe's Avatar
There have been several threads about axle ratios, engine speed, and road speed over the years. One thread that had lots of discussion is this one: https://fordbarn.com/forum/showthrea...5747&showall=1
For quick reference in this thread see the table below. Since this table is probably not easy to read in this forum I have also attached this as a pdf, which you can download for easier viewing. All these ratios are for 28 inch tall tires.
File Type: jpg Early V8 rpm vs speed for various driveline combinations.jpg (130.3 KB, 42 views)
Old 12-10-2024, 08:01 AM   #6
HDowse
HDowse's Avatar
38 Coupe, thanks for that comprehensive chart. I have a 26% Mitchell in my 40 DeLuxe with a 4.11 rear end it's interesting to see the rpm drop in overdrive.
Old 12-22-2024, 04:41 PM   #7
danliveshere
Yes thanks for the pdf, great chart!
My buddy is building a blown flathead, 3 speed with an 8” rear axle, he’s trying to figure out the best ratio to suit his setup. Dan.
