Old 12-05-2024, 06:47 AM   #1
ScubaChief60
ScubaChief60's Avatar
Default Anyone ever hand crank their 85HP Flathead?
I have been wondering if anyone on this forum has hand cranked their flathead 85? I have the crank and see how it works... but never used it. I guess I am concerned that I may finally break an arm.
In all my 65 years I have broken every bone you can break and still function but oddly enough never an arm...
Information on hand cranking will be appreciated.
ScubaChief60 is offline   Reply With Quote
Old 12-05-2024, 06:55 AM   #2
richard crow
Default Re: Anyone ever hand crank their 85HP Flathead?
there is a movte on tcm every now an then penney ceranade & the car has a dead battery. its a 36 ford & the actor cary grant starts it by cranking
richard crow is offline   Reply With Quote
Old 12-05-2024, 07:07 AM   #3
ScubaChief60
I'll see if I can hunt up that clip on YouTube maybe
Old 12-05-2024, 07:41 AM   #4
joe 1950
joe 1950's Avatar
it’s been a while but here goes key on AND MAKE Sure ITS IN NEUTRAL set parking brake if it works install crank slowly bring engine too compression stroke most important is too keep your thumb on top of the crank bar give quick hard turn and if it starts you’ll feel like a real man. just a note start it with the starter first leave it warm up then try your crank good luck
joe 1950 is offline   Reply With Quote
Old 12-05-2024, 07:52 AM   #5
corvette8n
corvette8n's Avatar
Found this
https://youtu.be/DArvPMlxHeQ?si=Z-9a-SAKdUL25jVu
Can’t try it with my ‘41 as it has a replacement radiator with no hole.
Old 12-05-2024, 08:37 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
The 36 before it was taken apart to restore had a lazy starter and had to be hand cranked or pushed—- cranking was a 2 hand and spin it the compression strokes were too close together to flips it over like a 4 cylinder.
It can be hard on the grill and they cost too much now—- the grill it had it didn’t matter.
Old 12-05-2024, 10:42 AM   #7
Automotive Stud
Automotive Stud's Avatar
Never tried, but I feel like it would be easier to push it and pop the clutch...
Automotive Stud is offline   Reply With Quote
Old 12-05-2024, 10:44 AM   #8
Seth Swoboda
Seth Swoboda's Avatar
I can't hand crank start the engine in my Model A it's so tight. No way any of my V8 would be any easier.
Kurt is correct. It's too hard on the grille and they cost too much to replace/repair.
Old 12-05-2024, 11:21 AM   #9
tubman
tubman's Avatar
At the risk of repeating myself, I had a 1948 Seagrave pumper with a 468 ci Pierce-Arrow derived V12. I used to bet I could crank start it at car shows and always won. I have found that the more cylinders you have, the easier they are to start. A "one-lunger" fires every 720 decrees; a V12 every 60 degrees.
As mentioned above keep your thumb on the same side of the handle as your fingers and you'll be fine.
Old 12-05-2024, 11:24 AM   #10
hotcoupe
hotcoupe's Avatar
It is my understanding that Vincent Bendix invented the "Bendix drive" after a personal friend was killed attempting to manually crank an engine. And then, I'll never forget when I was in Vietnam a co-worker was hand cranking a "pony" engine ( two cylinder V configuration), the engine fired but ran backwards, the handle hit him in the head. Serious injuries resulted. Be careful out there!
Tom
hotcoupe is offline   Reply With Quote
Old 12-05-2024, 11:31 AM   #11
Tim Ayers
Interesting perspective. Haven't thought of it that way. Makes sense why my father's Gravely Model L's were so darn hard to start in the dead of winter.
Old 12-05-2024, 11:46 AM   #12
tubman
tubman's Avatar
It also helped that that engine had dual ignitions with 24 spark plugs, two distributors, and 4 coils. That's a lot of firing impulses in a 180 degree crank pull.
Old 12-05-2024, 01:03 PM   #13
ThirstyThirty
ThirstyThirty's Avatar
as I remember, my '36 grills were thin tin ~
"My Model A... work never ends, only the day ends!"
ThirstyThirty is offline   Reply With Quote
Old 12-05-2024, 01:05 PM   #14
ThirstyThirty
anyone ever see the youtube on the 500+ hp Model A engine that ran 238+ mph at Bonny few years back?....
Old 12-05-2024, 01:43 PM   #15
KiWinUS
KiWinUS's Avatar
I had to hand crank m36 when I first got it as a couldn’t afford a new battery all had had was a scrap battery that was only good for running ignition.
Old 12-05-2024, 07:01 PM   #16
fordv8j
fordv8j's Avatar
Back in the old days, did'nt have good battery, hand cranked our 38 DLXcoupe many times, a month ago thought I would try to crank it just for fun; it started right up, make sure it is in neutral, or you can run really fast
fordv8j is offline   Reply With Quote
Old 12-05-2024, 09:57 PM   #17
ScubaChief60
Thanks all! May give it a try... so I can have a plan B or C if battery ever dies. Plan B would be roll start it and pop the clutch. C of course the hand crank. I guess AAA or Hagertys is also in the mix.
Old 12-06-2024, 07:01 AM   #18
richard crow
i have seen model t guys turn the crank just right then jump on the running board & the car started
Old 12-06-2024, 08:27 AM   #19
33 tudor
I had a 28 model A,i used to hand crank it for fun,just be careful to hold the crank with your palm,dont let your thumb get kicked back,thats the most often injury.i used to bring it up to the top of compression,then all it tokk was a good push down and it usually fired up,the model la has the spark and throttle on the wheel,that heps a lot with starting too.
33 tudor is offline   Reply With Quote
Old 12-06-2024, 09:43 AM   #20
tubman
tubman's Avatar
I don't know how they did it with Model T's, but with a Model A, if you had the crank in the right position, moving the spark advance lever would produce a spark and the car would start.
I would imagine T's had the same thing.
