Has anyone sourced or made a rotisserie? Would love to buy or see plans! Thanks!
I had built a rotisserie off a set of internet plans 6 years ago. Knowing plusses and minuses from production units I modified mine while building it. Turned out great. Heavy enough to handle a 50's Cadillac.
Vic |
#3 | |
Super Moderator
Harbor Freight, about $1800. Did 15 restorations with this unit.
I wonder if Harbor freight still sells that?
Here's a few more: https://www.bing.com/search?q=harbor...ANAB01&PC=HCTS |
Super Moderator
I did add an adjustable rod to each end as the way it was built, there was only incremental adjustments. With a threaded rod, I could balance the body so easily and so well, I could spin it with one hand and it would stay where I placed it without locking.
I bought an Auto Twirler Rotisserie too and put a '65 Falcon on it to sandblast the underside. It sure beats laying on your back and sandblasting. Now I can sit in a chair and sandblast. I have a big sandblast cabinet too. It's taken me all of my life to finally get the tools I've wanted and a large shop.
The only place that sells the blasting sand near me is tractor supply. Last edited by Flathead Fever; 11-27-2024 at 05:57 PM. |
yes! Thanks!
Super Moderator
I don't think so.
I had made rails that went between the two "stands" of the body. On the rails I had pieces of tubing that were cut to the proper length so as not to put stress anywhere to the body. The tubes were 1" in diameter with an end plate welded on. That end plate was threaded so I could install a bolt directly into it. Then I would use factory body to frame mount holes. By utilizing the factory mount holes, I was able to touch in paint later as none would get beneath the mount at painting time. Once mounted with pads, etc. this "touching in" was not visible. I have attached a photo of a 40 convertible body mounted. This should make it quite clear how I mounted all bodies. I'd restored so many coupes and convertibles, I had "stands" made respective of body style, marked as to what they went to as well as the rail system marked.
#11 | |
