Old 11-24-2024, 04:55 PM   #1
ActionYobbo
ActionYobbo's Avatar
Default What are these holes for? 39 truck
2 holes in the dashboard. Don’t remember taking anything out of there
File Type: jpg 2CA996BD-589E-45B1-8162-16468BC3C862.jpg (54.0 KB, 85 views)
I am building a 1939 1 ton express
ActionYobbo is offline   Reply With Quote
Old 11-24-2024, 10:04 PM   #2
GB SISSON
GB SISSON's Avatar
Default Re: What are these holes for? 39 truck
I think one of them is for a tiny little toggle switch. Most of my trucks have it. IIRC it activates the dash lights? I never had one that worked, so I'm no expert in that realm. I use the other for momentary fuel pump switch..
Old 11-25-2024, 08:23 AM   #3
ActionYobbo
The switch for the dash lights on this truck was under the dash near the steering column left side. So I put it back the same. I will just leave those other holes empty. I only seen them for the first time yesterday when I was installing the dash trims. Never knew they were there before that.
Old 11-25-2024, 11:09 AM   #4
GB SISSON
GB SISSON's Avatar
I thought those holes were under the dash, left side of wheel. They are in the upper dash part with the hole for the windshield crank?
Old 11-25-2024, 12:30 PM   #5
ActionYobbo
Nah those holes are in the center under the winder. These holes are on the far left
Old 11-25-2024, 01:07 PM   #6
38bill
38bill's Avatar
The holes are for the upper bracket of the hand brake lever (if the brake lever is on the left side)
38bill is offline   Reply With Quote
