1933 model B
Now that I finally got my car running again, idles fine, but engine stalls when step on accelerator. Could it be a fuel pump problem? |
I doubt it is the fuel pump because the carburator should be full of gas when you step on the accelerator. The stock carburetor doesn't have an accelerator pump so it is not that. My guess is that it is in the carburetor, can you borrow another one you know works? By the way you should add your general location to your profile.
Charlie Stephens |
Do you have your mixture turned in too far on the choke cable. try turning it out a turn or so and see if it helps. I have seen bad condensors cause the same issue.
Have you tried turning the choke counter clockwise a little
to richen the mixture? Never mind Michael beat me to it. |
Your carb doesn't look like this?
no, my carb is a stromberg 97 carb
stromberg 97 carb installed with downdraft attachment
Whole entire different animal. Look into the accelerator pump.
HOW TO: Install 9631K-97 Accelerator pump | Stromberg
Probably easier (and cheaper) to fix, though.
#13 | |
Charllie Stephens |
#14 |
send it to uncle max
#15 |
#16 |
IS it me OR I would like to see JUST how a Stromberg 97 is working on a 33 4cyl (Model B) from what should be an "updraft" single barrel carburetor, right?
#17 | |
https://www.snydersantiqueauto.com/p...9386&cat=41733
#18 |
Making the simple complicated for over 30 years. Last edited by 51504bat; 11-07-2024 at 08:44 AM. Reason: Add info |
#19 |
Just wondering, is a 97 carb a bit much for a stock 4 banger?
#20 |
Lots of folks run either a Stromberg 97 or Holley 94 style carb - seems to work really well!
