Old 09-15-2024, 10:01 PM   #1
3W Hank
Default Generator pulley 59 for a fan bolt om
I has a the older 6V generator ( round cut off regulator ) and a pulley that one can bolt a fan to.
I will replace the generator to the never 40’s style 6V and separate regulator. The one I bougt has a pulley with no bolt holes to a fan ( se pic )
I saw one engine that had the never generator but a pulley with boltholes for a fan ( se pic )
But axle diameter is not the same so how is this done.
3W Hank is offline   Reply With Quote
Old 09-15-2024, 11:46 PM   #2
cas3
Default Re: Generator pulley 59 for a fan bolt om
There are lots of pulleys. you need to find the one for your gennie. 1st, what is your shaft, what size, and got a key way? Figger out what you need then look at ebay for the correct shaft size with a fan mount. Also, lots of different pulley diameters. what speed would you like to run your fan?
Old 09-15-2024, 11:52 PM   #3
Charlie Stephens
I think you are looking for a '39 standard generator and pulley. Check the Green Bible and see what else it fits.
Charlie Stephens
Old 09-16-2024, 03:14 AM   #4
deuce lover
deuce lover's Avatar
His pics are so small but it appears he has a 40-48 gen.Those 2 brush 39 std gen are tough to find.
Old 09-16-2024, 08:01 AM   #5
Tim Ayers
Charlie NY or anyone with a lathe can cut internal threads in an earlier pulley so it can thread on to the later thread shaft. As mentioned, the '39 standard pulley is a tough one to source.
Old 09-16-2024, 08:20 AM   #6
jimTN
If you put a threaded pulley on, better have a lock nut in front! They can unravel and send a fan into your rad.
Old 09-16-2024, 08:44 AM   #7
Tim Ayers
Good point, Jim. 100% accurate. On my maiden voyage with my roadster, after about 30 minutes of driving I was hearing this ting, ting, ting sound from the front as I revved.
I pull over to check it out and the pulley did just that. I did not have a nut on it at the time. Thank goodness no damage other than paint loss.
Old 09-16-2024, 11:28 AM   #8
tubman
tubman's Avatar
I may be out of my depth here, but isn't there a difference in the front bearings in pre-war generators depending on whether they were fan mounts or not? I seem to remember reports of problems with fans mounted on generators not specifically designed for them. I may be all wet, but if it were me,I'd like to be sure.
Old 09-16-2024, 02:55 PM   #9
3W Hank
I can click on my picture and they large and one could zoom to.
The pulley on my 40’s generator has maybe 1.5 thread out side so no nut was ever there.
My 30’s generator has a nut.
Se picture.
But how to remove the pulley, nowhere to wrench it (?)
Old 09-16-2024, 03:16 PM   #10
Newc
Newc's Avatar
About those '39 std/commercial generators. I HAD an old shop local source for them. Went in to visit, asked about buying them all, and was told I missed by one week, the shop sent 8- 55gal barrels of generators to scrap!! Sold the property and retiring. Apparently there is an aftermarket alternator [12V] available, fan mounted type. Newc
Old 09-16-2024, 05:13 PM   #11
Tim Ayers
I did find a NOS military generator (still in the wooden crate) that has the fan mounted pulley that screws on at Hershey for $30. It's a two belt pulley, but that doesn't matter to me.
Old 09-16-2024, 07:45 PM   #12
ndnchf
ndnchf's Avatar
Se picture.
To remove pulley, first remove the armature, front bearing plate and pulley as a unit. Then clamp the armature in a padded vice. Remove the small C-clip on the end of the shaft. Then unscrew the pulley, use a strap wrench if it is tight. It is a left hand thread.
ndnchf is offline   Reply With Quote
Old 09-17-2024, 02:01 PM   #13
3W Hank
It was no C-clip in front but I could remove the pulley.
It's cleaned up now in my tank.
I might can modify the older generators pulley that has bots to fan.
If I not will use the std set-up on generator I might not need do this ( I has sevaral solutions ) but my pulley was hurted, so who has the 40's style pulleys ?
Old 09-17-2024, 03:52 PM   #14
Kurt in NJ
Kurt in NJ's Avatar
The 3 brush pulley is a little thin to bore out to the larger shaft size on one side.
Old 09-17-2024, 04:24 PM   #15
3W Hank
Yes, that was my idea to look at this, but what pulley did the 40’s generator had on the Chris Unger cool 3W coupe has ? ( se pic )
Old 09-17-2024, 08:31 PM   #16
alchemy
alchemy's Avatar
Do not bore out the early pulley for use on the later armature (12 volt). Not enough meat there to last. Ask me how I know.
alchemy is offline   Reply With Quote
Old 09-17-2024, 08:59 PM   #17
Kurt in NJ
Kurt in NJ's Avatar
I keep looking at the flea markets there are 2 different diameters — the real generator has the ears for the mounting that look the same as the 3 brush generator.
The green book has listings with pictures.Educate yourself and go looking in the 1$ piles
Old 09-18-2024, 04:30 PM   #18
3W Hank
I will try find a std pulley to this ca 1942 generator, its said 21 A.
Old 09-22-2024, 09:57 AM   #19
ndnchf
ndnchf's Avatar
I think you are looking for one like this. A few days ago I picked up 30+ generators at auction. This rare bird was among them. It appears to be post-1940 by the two side terminals and B stamp next to the field terminal. I'm working feverishly to get ready for Hershey. I hope to have this one restored in time to display on my table.
Old 09-22-2024, 11:03 AM   #20
alchemy
alchemy's Avatar
Chief, you are a lucky man. I found a similar pulley on a rather large generator with a 40-esque front mount. I assumed it came from a fire truck or ambulance.
