Old 09-02-2024, 09:26 PM   #21
JayChicago
JayChicago's Avatar
Default Re: First time poster... with a couple of questions.
Originally Posted by dsglass95 View Post
With a 6 volt battery I have seen a consistent 6.3v at the coil every time I have checked it.
That is just battery voltage, which is what you see if engine happened to stop with points open. Not likely you would see that on every test, points are open only open 20% of the time. More likely points are corroded and preventing current flow. With the resistor in the circuit, when points are closed and current flowing, reading at the coil should be 3-3.5 volt. (The resistor drops voltage about 3 volts.)
I agree with others, send distributor to Third Generation. I would not try to work on one of these distributors myself. No timing marks on the engine to set the timing. Ford designed these distributors to be easily removed, work done on the bench, timing set on a machine, then bolted back on the engine. With new points and timing set by a pro on the machine, your distributor will be good to go for years.
Old 09-02-2024, 10:28 PM   #22
cas3
Nice car, lucky fella. Obviously, we need a spark to light the fire. once you get that sorted out, I believe you probably have some stuck valves affecting the low compression. If grandpa was running it occasionally with old gas the gunk will stick on the intake valve stems. A real cylinder leakage test would be Ideal, but a poor man can weld an air fitting on an old gutted out spark plug base, put the cyl at TDC and blow some (low) air in and see whats leaking. Air at the carb =intake valve, air at the exhaust pipe is exhaust valve. A real peasant would just spin the motor over ( all plugs removed) with his thumb over the plug holes. Any good cylinder will blow your thumb off with a bang, and the weak ones will "fluff". Next, the poor man will look in the holes while your helper spins the motor and see if you can see any valves that don't move as much as they should. Hard to see, and if sticking open they can be brought back to life with shots of oil and tapping down with an allen wrench.
Also, not mentioned yet is always when trying to bring life back to an old motor a few squirts of oil in each cylinder will bring up compression, perhaps enough to get it running, and if luck is with you it may improve after some miles.
good luck, happy motoring
Old 09-02-2024, 10:59 PM   #23
tubman
tubman's Avatar
I'll come right out and say ir. Both the "E-Fire" distributor and especially the Speedway carburetor are products of questionable quality and will only cause you more problems along the way. You will be better served by having the original distributor and carburetor gone through by reputable technicians here on "The Barn". Michael at "Third Gen Automotive" as mentioned for the distributor, and "Uncle Max" (Max Musgrave) for Stromberg carburetors are the best.
You can fool around with the aftermarket crap later if you want to, but nobody really needs that kind of complication in their life.
Old 09-02-2024, 11:01 PM   #24
Lanny
Lanny's Avatar
Alphonse Gabriel Capone, sometimes known by the nickname "Scarface" is one
of only a few that could have afforded to import that rare '32 in those days.
Did he happen to carve his initials inside someplace ?
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 09-02-2024, 11:16 PM   #25
cas3
Gotta agree with tubman, sadly the original carb could have been sent to uncle max for a rebuild for similar money as the new speedway junk. and... no comment on the fancy "new" ignition stuff
Old 09-03-2024, 09:29 AM   #26
Conrad Rossi
Conrad Rossi's Avatar
From the pictures looks like the cables are old and have been tampered, which could be giving you erratic current. I might be worth checking and replacing your battery cables. At least that was one of the issues I has when I was trying to fire up my +30 years dormant car.
One of the many things I learned here is the importance of having good grounds with a solid path to ground and the correct cables gages. If the cables are old, most likely they’re corroded inside and you can see it. Ground straps usually have their tinning look dull and you can see the copper underneath.
Ground path: battery to firewall, firewall, to engine. Then add a ground from the starter support bolt to a transmission bolt. Ensure all metal surfaces are shinny clean with no corrosion, including bolts.
One thing you can do if you haven’t done it already is disconnecting the fuel pump from the carburetor. Then, fill up the carburetor bowl with gas. It will give you about 20-30 seconds to run. Make sure you use the choke, which you will have to find out the right balance to get the car fired up. Use starting fluid. Once the car runs a couple of times, then you can fill in the bowl and connect it to the gas pump. I had to do this prime the carb despite having a functioning pump.
Good luck!
-Conrad
Conrad Rossi is offline   Reply With Quote
Old 09-03-2024, 10:04 AM   #27
TJ
TJ's Avatar
One thing to mention since you are new to flatheads and may work on the distributor is the offset cam on the rear of the distributor. The distributor has a cam in back the fits into a groove on the camshaft. The cam is offset and can easily be placed 180 degrees out of time. Make sure all lines up before you try to start the motor. If not placed correctly a lot of damage can be done to the distributor.
Old 09-03-2024, 10:58 AM   #28
Bored&Stroked
Bored&Stroked's Avatar
Just so you don't get confused by the prior post -- it is an offset "tang" that fits into a slot on the front of the camshaft. The tang is offset - so make sure you're not 180 degrees off and try to force the bolts in. Many a newbie has done this and cracked the distributor housing.
Not trying to step on TJ's shoes - he is mentioning a very important aspect of our 32 - 48 Ford Flatheads!
Old 09-03-2024, 01:34 PM   #29
drolston
drolston's Avatar
[QUOTE=dsglass95;2334979]
Originally Posted by drolston View Post
A start and a stumble is great progress! Do check that all cylinders are getting a spark, but also suspect that the reason it does not keep running is that the carburetor needs service. After cranking a bit, peek down into the throat of the carburetor; have someone pump the throttle to the floor a few times. Each time you should see the accelerator pump squirt a nice little stream of gas in to each barrel of the carb. If no, we will advise on how to work backwards from there to find out why the carb is not getting fuel. If yes, the situation is more complicated. Could still be ignition; could be carb main jet path gummed up.[/QUOT
I was blaming the carb at first, so that's why I replaced it with the Stromberg knockoff from Speedway. I also rebuilt the fuel pump with a NapCo kit from 3rd Gen. The gas tank is, in my opinion, beyond repair, so I have been running a hose from the pump to a gas can. It pumps good and the squirters in the carb are working. I have also tried to bottle feed it, also with no luck. It seems to light off quickly but then stumble and Die. The ignition switch was bad when I first tried to start it, so it is wired through a toggle switch, and has a new ballast resistor as well. With a 6 volt battery I have seen a consistent 6.3v at the coil every time I have checked it.
I can not argue wit those recommending a distributor rebuild, but I will note that I bought three 97 carbs from Speedway. The float was way off on all three, and one had a casting flaw that completely blocked fuel flow to the primary jets. That flaw would let the engine start and then die. Can you borrow a known good carb?
Old 09-03-2024, 07:50 PM   #30
dsglass95
The Stromberg that was on the car was/is in really poor shape, the throttle shaft was the loosest that I have ever seen. I priced the parts that would of taken to rebuild it,( I have rebuilt 100's of carburetors over the years), and it just wasn't worth it. So I looked for quite some time for a good used one and I was thinking about buying a new one. I got the Speedway carb on sale for less than half what a new Stromberg would be, so I went ahead and bought it. It obviously didn't fix my starting problem, but once I get it running, I will deal with the carb again if I have to.
dsglass95 is offline   Reply With Quote
Old 09-03-2024, 07:56 PM   #31
dsglass95
[QUOTE=drolston;2335121]
If there is any one left around me that might have one, I have no idea who it would be. So far, I haven't even been able to keep this car running even while bottle feeding it. The result is so far always been the same. Start briefly stumble and die. It wont even try to run on brake clean or starting fluid, not the last time I tried it anyway.
Old 09-03-2024, 08:11 PM   #32
dsglass95
Good luck!
I haven't looked to see if the motor is grounded to the body or not. But the motor is grounded directly to the battery, it was this way when we unburied it. As far as filling the float bowl goes, someone in the past had drilled a hole in the top of the carb that was on the motor, then capped it off with a grease zerk. I filled the old carb bowl dozen's of times and never was able to get it started.
Old 09-03-2024, 08:17 PM   #33
dsglass95
No, but the car was painted Midnight Purple when my in-laws bought it. My mother in-law said that they were told by the seller at the auction that it was a "Lady of the evenings" car. Wife wants to paint it Midnight Purple again too. Lol
Old 09-03-2024, 09:45 PM   #34
DavidG
DavidG's Avatar
Somewhat off topic, but your engine compartment photos bring back memories of the many cars that I brought back from Argentina, Brazil, and Uruguay in the early 70s and early 90s when on assignment there with Ford, namely the work of many like-minded Rube Goldbergs.
Your car is a rarity, however, if those fenders on it are the ones that were on it when it left Argentina. Not a lot of lane discipline down there, at least in the past, so fenders got bent, repaired, bent, and repaired to the point where there was no life left in the metallurgy. Of 30 or cars that I exported, only 3 did not have to have all four fenders replaced. But the climates of southern Brazil, Argentina, and Uruguay are car friendly and new cars were so expensive that there was a lot of incentive to keep the old cars in regular use right up into the 1980s.
All of the Fords that I retrieved were open cars for the simple reason that all of the good '32-'34 closed cars that I found were rendered not worth the effort by virtue of the local (and in my opinion, bad) habit of welding in the roof opening. Your car appears to have escaped that fate.
Fordor sedans are my second-most favorite '32 closed body types. I really like their proportions, styling wise.
Old 09-03-2024, 10:07 PM   #35
cas3
Being a new guy, Ill say folks here are trying to help. Your choice of a speedway carb would have probably been changed if you had asked first. Speedway sells some useful parts, some good, some not so good. Carbs are not on the good list. Uncle Max only works on stromberg carbs, re bushes the throttle plates, new real stromberg parts thruout,
re does the finish on the whole carb, all new screws, all linkage replated, and its tested and adjusted on his flow bench before its shipped out. When you get it, you bolt it on and it runs perfect.
I too have rebuilt all kinds of carbs thru my life, but this is done right. Last one was about 225 if I remember, and they look like new.
File Type: jpeg 95DCC2EB-51AF-461E-96F5-D3EC490D2D0E.jpeg (98.5 KB, 39 views)
File Type: jpeg AD73A645-F3C3-46B1-9B81-02286746C932.jpeg (95.4 KB, 38 views)
Old 09-03-2024, 10:30 PM   #36
cas3
I'm gonna add one more comment, as a general rule, Henry built a good car, thats why many have survived, and generally command a higher price than a similar brand X.
So keeping it as much real ford parts as one can in todays world will probably give you more joy and happy motoring. New, is not necessarily better.
Old 09-07-2024, 01:10 PM   #37
dsglass95
Hello all. I am back with a update on some of the suggestions that were given to me. I had time this morning to check for spark at the plugs. Found the plugs #4,8 and 5 were not firing. #4 and 8 were just the end of the wire at the plug needed cleaning, but #5 was corroded in the cap to the point that it broke while trying to get it apart to clean. So When I reach out to Third Gen on getting the distributor rebuilt, I will put new caps, wires and plugs on it at the same time. That brings me to the coil. This coil isn't stock, but the primary ohms at zero, while the secondary is at 3.4 ohms. I have never checked a 6 volt coil before, but since this car used a ballast resistor, I am believing that no resistance at the primary side of the coil is good. If I am making the wrong call on this, please let me know. Here are a few pics of the coil. Thanks.
Old 09-07-2024, 05:37 PM   #38
tubman
tubman's Avatar
You want some resistance on the primary windings, say 6 or 8 ohms. On the secondary, you want to see 15,000 to 20,000 ohms, maybe even higher. You may be reading the wrong scale on the ohmmeter. Since resistance can vary so much, most meters have variable scales. There is usually a knob or something to switch between them. Testing the primary while set to a high scale can make it appear that there is zero. There has to be some primary (and secondary) resistance, since you are getting spark.
Since that is an aftermarket coil, there's no telling how old it is. Most original Ford coils have long since given up the ghost due to age. They can be renewed.
Old 09-07-2024, 07:28 PM   #39
dsglass95
Thanks for the info. It appears the this coil is bad then. My older meter shows 0 at any setting above 200, and my Fluke with auto range shows .7. I was able to get a Ford part number (18-12024) by finding the part number on the condenser,(68-12300), So I will be reaching out to Skip Haney to see if he can fix this one or not. Thank you to Blindhuckster for the links as well.
Old 09-08-2024, 09:10 AM   #40
Bored&Stroked
Skip can rework/rebuild the coil and he will most likely advise you to get a new condenser. I'm not sure who is "building" condensers these days for these Diver's Helmet distributors. The old (even NOS) condensers tend to be dried out and worthless - so having a good condenser is a must. I use high-quality magneto condensers on my crab style distributor rebuilds (Harman Collins dual-coils) - they are expensive, but tend to be about the only ones I can find that last (at least in my world!).
I know that guys have retro-fitted non-original condensers to fit into these coils - you may ask Skip what he recommends and can he supply you with a tested setup. If it was mine, I'd modify a magneto condenser to fit (some fabricating, soldering, etc).
