looking for two lower 8AB radiator hoses ( 91A-8286B ) that are non-scrip radiator hoses. Found several but scrip, Drake wants $40.00 each ! I just want to get two new dependable hoses to get on the road. thanks in advance for your time,
I believe I heard that laquer thinner takes the printing off the hoses quite easily.
Super Moderator
You had heard correctly. A little thinner on a rag and a little rubbing. A minute later and no more script.
Check rock auto or your local auto parts store for a generic hose and then cut it to lenght..
-Conrad |
I just go to the local parts store and match it up to something I can cut it out of. You'll find something that will work.
Thank you, I did not mind the scrip, I am going to remove the hoses to drain and flush the the system and radiator, also replace the the front brake line.
I was just needing new hoses after 40 years of the current hoses on car I did not think they will/would come off without having to cut off to remove. Will try parts stores to see what they can order. Appreciate Help |
Midwest Early Ford has them,non Ford Script.$35 pr.
