The starter ring needs to be replaced. I pulled the engine and have removed the 4 bolts holding the lower bell housing. What's next?
do you have a two piece oil pan? if not you must remove the oil pan to get the flywheel out
do you know what engine you have--which should have been my first question--markings on the heads--pictures --description which will help us determine your engine
if engine is of 39 era sump and flywheel lower half are one piece
In the US, sump means oil pan.
