Old 08-11-2024, 06:54 PM   #1
John06
Default How to remove lower bell housing on 39 v8
The starter ring needs to be replaced. I pulled the engine and have removed the 4 bolts holding the lower bell housing. What's next?
John06 is offline   Reply With Quote
Old 08-11-2024, 07:28 PM   #2
alanwoodieman
Default Re: How to remove lower bell housing on 39 v8
do you have a two piece oil pan? if not you must remove the oil pan to get the flywheel out
Old 08-11-2024, 07:30 PM   #3
alanwoodieman
do you know what engine you have--which should have been my first question--markings on the heads--pictures --description which will help us determine your engine
Old 08-11-2024, 07:45 PM   #4
aussie merc
aussie merc's Avatar
if engine is of 39 era sump and flywheel lower half are one piece
aussie merc is offline   Reply With Quote
Old 08-13-2024, 07:10 AM   #5
alchemy
alchemy's Avatar
In the US, sump means oil pan.
alchemy is offline   Reply With Quote
Old 08-13-2024, 09:57 AM   #6
rotorwrench
rotorwrench's Avatar
The truck pans have a trap door so they could remove the 11 inch clutch on those so equipped. The car pans, not so much.
