#21 |
Flathead Fever’s suggestion is easy and eliminates one of the two possibilities….
My feeling is fuel problem…..you said it starts after you pour fuel in carb…of course you have to consider how much time elapses before you pour fuel…..too long …temp might drop enough To revive electrical components |
#22 |
#23 |
Here is a website that lists gas stations that sell non-ethanol gas in the US and Canada.
https://www.pure-gas.org/ |
#24 |
I replaced the ignition coil, the condenser, the engine still runs for 30 minuets and then stops, make and excellent timer. Every 30 minuets. I think if the mechanical pump were bad it wouldn't run for 30 minuets right. It seemed like I could accelerate better without as much engine coughing.
#25 | |
. We used to live in Oregon (but not Portland) and couldn't pump your own fuel.
#26 |
On my dad's flathead powered '32 roadster I've taken a 5-gallon can of gas and a 1 1/2 lb. electric fuel pump. stuck it in the cab and bypassed the entire fuel system. That way I knew for sure if it's a fuel problem (be careful). I have the tank out of it right now, it was full of junk. And then I had a stroke, so it hasn't gone back together yet. You could tee in a pressure gauge on the output side of the pump and see what the pressure is when you first start it and then what it is when it quits. Last edited by Flathead Fever; 07-05-2024 at 01:32 PM. |
#27 |
There could be some other issue going on, but with the low quality of new points, condensers, coils, etc one of those could still be your problem. This is what drove me to a Pertronix ignition, and I have not looked back. They make a unit for Ford 4 cylinder positive ground.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
#28 | |
#29 |
I will next rebuild my fuel pump. Perhaps it is marginally working and eventual cuts out?
#30 |
I went out this morning and figured everything was cooled down. I could not start the car even after pouring a little gas into the carb. Usually always works.
The battery was very low. I am trickle charging it now. This happen one time before when the car stopped running. I noticed then that the batter was low. Could a low battery kill an engine? The last time that happened I charged the battery and the car started up and ran perfectly. |
#31 |
A low battery will kill the engine if your not charging when running
#32 |
#33 |
See post #16 on this thread
https://www.fordbarn.com/forum/showt...76#post2322776
#34 | |
#35 |
Went out first thing this morning poured a little gas into the carb. The car won't start at all. Whatever was going finally went all the way. Now the fun begins?
#36 |
Compression will not go away on all pots within days so your engine has probably only fuel or ignition problems. If battery is fully charged and voltage reaches the coil,First check for a healthy spark, next is spark timing. Change or clean those wet plugs before attempting another start. If carbs float chamber is full, engine should start and run for a couple seconds even without a working fuel pump.
#37 |
Thanks Vincent for your clear advice. I will do as you recommend.
#38 |
removed spark plugs, carbon buildup on all 4 plugs. I cleaned them and put them back in the engine. Tomorrow I will check for a spark. I guess I need my wife to step on the starter while I and holding a plug, welders gloves to see if I get a spark.
#39 |
my car ammeter was jiggling when trying to start, but still not start.
I guess coil is ok but not have to check from distributer contact to spark plug. One strange thing was horn works but headlights do not? What the hell is going on? |
