#141 |
OldGold,
You continue to impress!! |
#142 |
Are these car or truck floorboards?
#143 |
Floor Boards look too good to cover up.
Pics of capped studs used with floor mats and clips used with carpets, found (purchased) on ebay 2008 |
#144 | |
#145 |
Toml,
Gold in different forms. Congratulation! David |
#146 |
#147 |
#148 |
The one year only 1932 Ford parking brake pawls (sector) is now available
https://thirdgenauto.com/product/193...ke-lever-pawl/ |
#149 |
I was asked if I could make some of the Ignition Lock Switch Cases for 38-39 Cars and 38-47 Pickups and Trucks, part number 81A-3712. These are made in small batches but at least they are now available to those needing this part.
https://nwclassicparts.com/products/...ck-switch-case Last edited by OldGold360; 10-18-2024 at 11:42 AM. |
#150 |
It appears both Drake and Vintique have quit on this item... So my version, 3D printed in a flexible plastic.
#151 |
Karl,
Thanks! |
#152 |
1935-36 Cabriolet top iron to body hinges. What I have photographed is a 3d plastic model as I will only be making these when I have a confirmed order. (I expect demand to be very underwhelming).
Karl |
#153 |
Wiper/Hinge covers are now available for your 1937 Pickups and Trucks. I know several members here have inquired about the possibility of me making some. It’s been a long time coming. You can find them at www.nwclassicparts.com or reach out to me here via PM. Thanks!
#154 |
great looking parts.
#155 |
Here’s one for you 38-39 Pickup and Truck owners. These are now available on the website.
https://nwclassicparts.com/products/...t-repair-panel Last edited by OldGold360; 11-21-2024 at 08:17 PM. |
#156 |
1935-36 Phaeton top saddles.
Investment cast stainless. Unpolished for now, may offer polished later. |
#157 | |
#158 |
These are the "wedgies" that mount in the top irons at the upper rear corner of each window opening. Drake sells the pad that mounts into them. These are investment cast aluminum. I will be selling each, there are uppers/lowers/RH and LH.
#159 | |
#160 |
Not a huge crowd of folks needing this but we now have 1932-33 Detroit Lubricator gasket sets.
https://thirdgenauto.com/product/193...-hardware-set/ |
