Old 05-30-2024, 07:22 PM   #1
34fordy
34fordy's Avatar
Default Tolerance-Ford aluminum heads
Is there a tolerance amount that can be overcome with proper torque application for the flatness of a Ford aluminum head horizontally and vertically?
34fordy is online now   Reply With Quote
Old 05-31-2024, 09:08 AM   #2
Ol' Ron
Ol' Ron's Avatar
Default Re: Tolerance-Ford aluminum heads
when installing heads, especially Aluminum ones. I torque to 45 ft/lbs for three heat cycles. This is because the block has thick and thin thread holes. the heat cycles has a chance to have an even torque over the entire head.
Gramps
Old 05-31-2024, 01:08 PM   #3
34fordy
34fordy's Avatar
I don't think I asked the question properly. Overhead valve heads are quite thick and I don't think one would want them to be more than a couple thousands from being perfectly flat at the gasket surface. The Ford factory aluminum heads are thin compared to the O'head valve heads. I wondered if the allowable amount of gap either way could be greater on the Ford heads assuming that there might be a few thousands flex in them, as they are not as thick.
Old 05-31-2024, 01:28 PM   #4
KiWinUS
KiWinUS's Avatar
No problem Don’t over think this.
Old 05-31-2024, 01:35 PM   #5
cadillac512
cadillac512's Avatar
At first it would seem that way. However, any excess out-of-flat in either direction will require some extra amount of bolt torque to overcome the warp and bring the head back to flat. From that point the clamping force needs to be brought on up to proper spec. If the warp is minor the chances are pretty good it'll work ok.
It'd be interesting to install the head on a block with no gasket and see how tight the bolts need to be to bring the head down to flat...using a .001" feeler gauge to check.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is online now   Reply With Quote
Old 05-31-2024, 03:33 PM   #6
34fordy
34fordy's Avatar
[QUOTE=cadillac512;
It'd be interesting to install the head on a block with no gasket and see how tight the bolts need to be to bring the head down to flat...using a .001" feeler gauge to check.[/QUOTE]
That is an EXCELLENT idea for aluminum or iron!!!!!
Old 05-31-2024, 03:37 PM   #7
vincent
Verify that the block is indeed flat...
vincent is offline   Reply With Quote
