Old 05-25-2024, 07:04 AM   #1
Tim Ayers
Default Tips or a product that will clean radiator hoses?
I have some NOS 21A radiator hoses that I would like to use. They are dirty from lying around all these years. I tried using Dawn dish soap to clean them up, but it doesn't seem to work.
Anyone have any tips/products that they've used to get radiator hoses black again?
Old 05-25-2024, 07:26 AM   #2
Kube
Super Moderator
Kube's Avatar
Default Re: Tips or a product that will clean radiator hoses?
Lacquer thinner & scrubby pad.
Kube is online now   Reply With Quote
Old 05-25-2024, 09:08 AM   #3
Tim Ayers
Thank you! Worked great, Kube.
Old 05-25-2024, 11:34 PM   #4
Lanny
Lanny's Avatar
Tim, get a tube of Lanolin Cream, Walmart has it. It will help
keep rubber pliable and looking good...
l
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 05-26-2024, 07:59 AM   #5
V8 Bob
V8 Bob's Avatar
I had very good results cleaning/restoring my Drake '40 running board rubber that had collected dust for over 30 years with Simple Green. They came out looking like new.
Old 05-26-2024, 08:19 AM   #6
Tim Ayers
Thanks, all. Will check out all the suggestions.
Old 05-26-2024, 09:34 AM   #7
cmbrucew
cmbrucew's Avatar
Used brake fluid for running boards.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 05-26-2024, 10:16 AM   #8
sshep
I used Yuengling Lager. After I drank a dozen or so of them, my old hoses looked great. I didn't even have to touch them. An old friend of mine introduced me this trick years ago. Works on anything, give it try.
sshep is offline   Reply With Quote
Old 05-26-2024, 04:39 PM   #9
Tim Ayers
Ah, yes. A little Vitamin Y always does the body good.
Old 05-26-2024, 05:04 PM   #10
47topless
47topless's Avatar
Wink Re: Tips or a product that will clean radiator hoses?
Too Funny!!!
In my formative years, this technique used to work well on womens.
47topless is offline   Reply With Quote
Old 05-26-2024, 09:09 PM   #11
itslow
itslow's Avatar
Way to close for brake fluid to be to painted surfaces for my comfort level.
Mike
Wanted:
- '32-34 Open Cab Pickup (RPU) parts and documents/articles/info
- ARDUN parts
itslow is offline   Reply With Quote
Old 05-26-2024, 09:24 PM   #12
1952henry
1952henry's Avatar
As mentioned, lanolin, and another altenative, castor oil, after cleaning. No reproductions exist for F2-3 rear axle bump stops, so I made some. After shaping and smoothing, I gave these a rub down with castor oil. Not perfect, but presentable. Picture is deceptive, side by side, the “made” stops match the originals. Wasn’t able to duplicate part number on mounting surface.
I dig coal, which provides motivation for EVs.
1952henry is offline   Reply With Quote
Old 05-26-2024, 11:39 PM   #13
petehoovie
petehoovie's Avatar
Old 05-27-2024, 01:59 AM   #14
69a
Sugar Soap. Good for tires too.
69a is offline   Reply With Quote
Old 06-02-2024, 01:15 PM   #15
Gary Tosel
Gary Tosel's Avatar
I have used Wesley's Whitewall cleaner for my running boards and my Blackwall tires as well and it cleans well and the rubber looks like new. It probably would work on radiator hoses as well.
Gary Tosel is offline   Reply With Quote
Old 06-02-2024, 01:40 PM   #16
deuce_roadster
deuce_roadster's Avatar
Lots of products listed here. I always use Urethane or Enamel Reducer for cleaning rubber. I have found it cleans it without leaving any "residue", just clean rubber.
Old 06-02-2024, 03:45 PM   #17
miniceptor86
miniceptor86's Avatar
Even the ladies.
Cheers,
Jim&Sandy
McGregor, IA
miniceptor86 is offline   Reply With Quote
Old 06-02-2024, 03:47 PM   #18
miniceptor86
I have used McGuires tire and wheel cleaner on tires and running boards. Leaves a very black and no sheen surface.
Cheers,
Jim&Sandy
McGregor, IA
Old 06-02-2024, 10:25 PM   #19
Yoyodyne
Yoyodyne's Avatar
Awesome from the Dollar Tree and a scrub brush, finish with a pressure washer if you have it. Laquer thinner, paint thinner, mineral spirits, Prep-sol all seem to work well also.
Yoyodyne is offline   Reply With Quote
Old 06-02-2024, 11:03 PM   #20
Lanny
Lanny's Avatar
I did a search on what Lacquer thinner does to rubber !!!
What does lacquer thinner do to rubber?
Due to its solvent properties, paint thinner can cause rubber materials to swell
and degrade. This can lead to cracking and decreased flexibility, ultimately
leading to failure.
