Old 05-20-2024, 09:03 PM   #1
mick1
Default Left ignition switch on
Hello all, have a 41 stock, everything working good till I left my ignition switch on, probably on for days….now I get nothing, no electrical at all…what did I blow, and could it have fried my points?….thanks for any advice!
mick1 is offline   Reply With Quote
Old 05-20-2024, 09:14 PM   #2
alanwoodieman
Default Re: Left ignition switch on
fried points/ burned coil, friend ign resistor are some of the main concerns
Old 05-20-2024, 09:22 PM   #3
Bob C
Have you charged the battery?
Old 05-20-2024, 09:29 PM   #4
dean333
dean333's Avatar
Send a message via Yahoo to dean333
I did that on my 37 last year for about 15 minutes. Melted the coil but luckily nothing else damaged.
Tim Carlig
dean333 is offline   Reply With Quote
Old 05-20-2024, 09:30 PM   #5
deuce_roadster
deuce_roadster's Avatar
Send the coil to Skip Haney and the distributor to one of the people here that sets them up on machines and learn from your mistake. If it now doesn't have any voltage at the coil, replace the resistor. It should give you lots of good service after this.
Old 05-20-2024, 10:06 PM   #6
mick1
The battery is flat dead, tried to put a charge into it but didn’t seem to take a charge, will try another battery tomorrow
Old 05-20-2024, 10:33 PM   #7
Joe B.
Joe B.'s Avatar
Check and see, if the points were open, the ignition system should be OK, I think.
thread killer
Joe B. is offline   Reply With Quote
Old 05-20-2024, 11:06 PM   #8
Lanny
Lanny's Avatar
Connect a set of jumper cables from a known good battery,
(even 12 volt should be OK) pos to pos post, neg to neg post
to get some juice flowing in to your dead battery.
After 1/2 hour, dis connect the jumper cables and then hook
your charger up and hopefully your battery will take a charge.
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
What I GOT DONE TODAY...
I got the rear-end put in the recliner, and
now I'm going to rest up & watch TV
Lanny is offline   Reply With Quote
Old 05-21-2024, 12:10 AM   #9
ford38v8
ford38v8's Avatar
Lanny, we don’t often see you post here anymore, but when we do, we can count on your advice to be good!
…Oh, by the way, us ketchup lovers gots to stick together, right? 😋
Alan
Old 05-21-2024, 06:54 AM   #10
corvette8n
corvette8n's Avatar
Try getting one of these for the future, the bottom one is a Cole-Hersee switch made in the USA, they show up on eBay frequently. Avoid the Chinese Amazon versions. Mine is mounted through the firewall on my ’41 and I just reach under the dash to switch it off.
Old 05-21-2024, 07:22 AM   #11
rockfla
rockfla's Avatar
OR another way of doing it is just disconnect the "hot" side battery cables as soon as you get home and in the garage. Also its cheap insurance IF you keep a battery maintainer on your battery from current flowing into the car while your not driving the car.
Old 05-21-2024, 09:47 AM   #12
oldbugger
oldbugger's Avatar
If your like me, if i forget the ignition switch i will sure forget the battery disconect switch. dont get old if you can help it.
oldbugger is offline   Reply With Quote
Old 05-21-2024, 10:41 AM   #13
petehoovie
petehoovie's Avatar
Old 05-21-2024, 11:19 AM   #14
rockfla
rockfla's Avatar
Just removing the hot battery cable is the "SURE fire" way, OR "SURE NO-FIRE" way. AND fire with at least a "dual" meaning.
Old 05-21-2024, 12:44 PM   #15
woodiewagon46
I did that once with a Model A "pop out switch" that didn't seat. It didn't toast the coil but burned the end off the wire attached to the coil. New wire end and it started right up.
woodiewagon46 is offline   Reply With Quote
Old 05-21-2024, 02:48 PM   #16
mick1
I put a hard charge into the battery, I got lucky, the engine fired up and ran normal, still wiping the sweat off my head, as I had just had the helmet distributor completely gone through new everything and Skips coil,,,,thanks for everyone’s input!!,,,,oldbugger……too late I’m already there😝
Mike Mickelson St.Paul Mn
Old 05-21-2024, 02:56 PM   #17
rockfla
rockfla's Avatar
Great news and great to hear. Congrats
Old 05-21-2024, 03:24 PM   #18
oldbugger
oldbugger's Avatar
your lucky day, enjoy!
Old 05-21-2024, 03:24 PM   #19
drolston
drolston's Avatar
Note: If the battery is completely dead, a so called "smart charger" can not detect the state of the battery and will not start to charge it. Too smart for its own good. If the smart charger has a battery maintenance function (trickle charger), you can put that on for a few hours; that will put enough charge on the battery for the smart charger to work. Or you can do what I did an buy an old dumb charger (Western Auto) to get the totally dead battery started.
Old 05-22-2024, 03:08 AM   #20
fortyonerag
fortyonerag's Avatar
I put my battery cutout switch under the battery tray on my 41.
You can't see it, and it has put me into a routine of a quick visual on the engine bay before and after taking her out.
fortyonerag is offline   Reply With Quote
