I recently scored a repro KRW engine lifting bracket but the 2 knurled pins are missing. Can anyone advise the measures (or a simple drawing) for the pin so I can make them?
The pins are .500 x 2.375 that fit into the bracket and have a .750 x .500 length head. The over all length is 2.875 including the head .
A picture and let me know if I can help as I have a machine shop
Wanted Ford oiler oil cans Thanks |
#3 | |
#4 | |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
It fits in the valley and the two pins drop inside the heat risers.
#8 | |
#10 | |
Tim from my experience using the KR Wilson one I have if its turned around the lifting bracket will not sit flat on the inside surface of the valve chamber. Ronnieroadster
I use the F word a lot no not that word these words Flathead, Focus and Finish "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 First Ford flathead roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH reset the record in 2024 to 211.830 running to mile four. Top speed 2024 mile five 220.672 exit speed 221.587 |
Perhaps in the other position it's for if a transmission is attached?
I made a adjustable lifting plate for my flatheads.
#13 |
adjustable lifting plate - outlaw |
#14 |
I got this one off ebay and works great.
#15 |
Ahh. Interesting. I don't own one, but I've thought that's how it worked. Thanks for setting me straight. I've been on the hunt for one for years. They've all seem to have disappeared.
#16 |
